Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 9:30am and include delivery.
Toshiba 47WLT66, Sony 46V2000U, Sony 40X2000U or Sony 46S2010? Which one? plank_of_wood LCD Televisions 9 27-08-2006 7:52 PM
Old 22-06-2008, 9:10 PM   #1 (permalink)
Sony PMW-EX1
To avoid confusion with my other thread regarding the Panasonic HVX 201 I am starting this new thread.My wanderings through the internet and various helpful replies have brought me to the above camera.Would it still be considered portable enough for my travels using monopod/tripod and occasional handheld for snap shooting?In my previous thread I ended up leaning towards the Sony HVR-V1E,how do these two cameras compare in particular with my wants, i.e. quality,ruggedness,portability? I thank you again in advance for any replies,feel like I'm working my way through a confusing field of choices.Cheers,Neilmac.
Neilmac48 is offline   Reply With Quote
Old 23-06-2008, 7:02 AM   #2 (permalink)
Thanks: Gave 6, Got 109
Re: Sony PMW-EX1
http://www.letsgodigital.org/en/1683...-hd-camcorder/
its bigger so obviously less portable,footage should have the edge on the v1 but its pros and cons.
hear is some threads on this machine http://www.sonyhdvinfo.com/forumdisplay.php?f=51
http://www.dvinfo.net/conf/forumdisplay.php?f=150
if i was getting a cam of this price and size i would prefer the z7 to the ex1 although it does not output 35 mpbs but thats me.
chrishull3 is offline   Reply With Quote
Old 23-06-2008, 6:16 PM   #3 (permalink)
Thanks: Gave 425, Got 2,078
Re: Sony PMW-EX1
I think the V1 is lighter. The EX 1 seems a tad more rugged in build even though in dimension it is not a lot bigger ( It is taller)
In short the EX1 is a little less portable but its video is "to die for" as they say
The V1 is however by no means a poor relation
The differences boil down to the fact that HDV is considered a "step " below XDCAM in Hi def stakes and machines using the XDCAM are placed a step "above"
So they are really not directly comparable as the EX1 is aimed squarely at the Pro Market . Its Fujunon Lens is apparently better( a matter of degree )
Can I suggest you look at the Sony Z7? which features interchangable lenses and also records to Compact flash cards as well as HDV tape?
I think it can compare with the EX1 ( format aside)
PS:Just seen Chris suggested it as well
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is online now   Reply With Quote
Old 23-06-2008, 6:35 PM   #4 (permalink)
Re: Sony PMW-EX1
Thanks for the links Chris I'm taking it all in-I hope! At least I'm narrowing my search down.Cheers,Neilmac.
pmwex1, sony
[IMG] code is Off
