Originally Posted by Bodger15 Sorry to be a bit of a Div, but can you put all this in language that is simple and easy for a novice to understand. |
Can I suggest you explain exactly which part of the explanations you don't understand.
Although they may not appear simple for you to understand but they are not intended to confuse you.
It may be that it is actually difficult to explaining in simpler language than that
My Sony DVD Home Theatre System lists many CD and DVD formats it can play but does not mention AVCHD, so will I need to change the DVD player for Bluray...??? |
AVCHD is playable by a Bluray player but simply buying one may not get you there
Lurchers posts suggest that AVCHD content which has been burnt to a DVD disc in a specifc way "AVCHD disc" playback on the PS3 ( when it is acting as a Blu ray player) or a Sony BD player. So just buying any Bluray player may not be the thing to do.
Also if you did get a Sony player, just burning the AVCHD files as a data disc will not ensure playback ( as it would on a PS3)
