Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 24th at 7:30am and include delivery.
Adobe Premiere Pro 2 [Need help] lolage Camcorders and Video Editing 1 12-11-2007 1:19 PM
Editing with Sony HDR-HC1E and Adobe Premiere pro - capturing in DV? nms Camcorders and Video Editing 4 21-12-2006 8:47 PM
adobe premiere - export movie problems nem123 Camcorders and Video Editing 45 27-03-2006 10:23 AM
Adobe Premiere stutter nem123 Camcorders and Video Editing 1 30-01-2006 12:00 AM
Adobe Premiere help please... Lex Camcorders and Video Editing 4 30-09-2002 5:54 PM
Old 30-05-2008, 8:10 PM   #1 (permalink)
Thanks: Gave 12, Got 48
Problems editing MPEG in Adobe Premiere
Don't know if anyone can help, but I've got a quick question on behalf of a friend who's trying to edit a bit of footage from a DVD (with permission) using Adobe Premiere 6.
After renaming the two VOB files as MPG, when he tries to import them into Premiere, it says: "Unable to open file. File recorded at unsupported rate. Rates supported: 11,22,32,44,48 kHz."
According to my Ulead, it just appears to be a bog standard MPEG2 DVD-PAL file, with a pretty high (9.3 Mbps?) video rate and Dolby AC3 audio @ 48kHz. It plays fine on his computer (in Windows Media Player etc), and he's also downloaded AC3filter in case that helped with the Dolby audio codec. I may just have to turn it into an AVI for him to put into Premiere, but any ideas for this, or to help next time round please?
Thanks!
Edit: just noticed ver. 6 is actually quite ancient - perhaps it can't edit MPEG2?...
felix2 is offline   Reply With Quote
Old 30-05-2008, 8:16 PM   #2 (permalink)
Thanks: Gave 425, Got 2,079
Re: Problems editing MPEG in Adobe Premiere
Does Premiere 6 edit mpeg?
I wonder .
I think Mpeg editing support came with ver 6.5
IIRC Mpeg support with ver 6 was "rudimentary" , as such it was very choosy which mpeg files it would import for editing, if at all
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 30-05-2008, 8:25 PM   #3 (permalink)
Originally Posted by felix2 View Post
I imagine that is the Problem TBH
It is about 4 generations old (2001/2002)
S3Stuff
Old 30-05-2008, 9:14 PM   #4 (permalink)
Thanks: Gave 5, Got 114
Run your files through virtual dub mpeg 2 export as dv -avi then premiere wil be happy
jaymac is offline   Reply With Quote
Old 01-06-2008, 12:03 PM   #5 (permalink)
Thanks guys, I hadn't realised quite how ancient Premiere 6 was (fancy changing their numbering system so they're now on CS3! Not that Serif makes any more sense, when MoviePlus version 6 finally comes out, they were going to call it X2, but because it's been a long time coming are now apparently going to call it X3!!)
I've just converted the clips in Ulead (knew it was good for something! ), also downloaded virtualdub mpeg2, looks handy. And I'll just have to persuade him to get some dosh out and spend some money on software written at least in the last 5 years!! Thanks again.
Old 01-06-2008, 12:57 PM   #6 (permalink)
Even more confusing premiere pro 2 is way above 6 why not consider premiere elements 2 you can get that reasonable now newere versions and that will import dvd
Old 01-06-2008, 1:05 PM   #7 (permalink)
Or Elements 3.. Im not even sure ver 2 ( even second hand) is still around.
S3Stuff
Old 01-06-2008, 3:18 PM   #8 (permalink)
Thanks. Yes, I see on Wikipedia (and why should I doubt such a respected tome?! ) the main releases of Adobe Premiere were: 6 (2001), 6.5 (2002, with DVD support), Pro 1 (2003, rewrite), Pro 1.5, Pro 2 (2006), Pro CS3 (2007).
Personally I'd try and persuade him over to Vegas - at least I'd have some clue what he was doing then! But I understand the Adobe forums are good too. At the very least I'll get him to get hold of Virtualdub mpeg2 &/or Ulead DVD Movie Factory in the meantime anyway.
adobe, editing, mpeg, premiere, problems
[IMG] code is Off
