how long should AVCHD importing take?
Old 30-05-2008, 10:37 AM   #1
45,485, Level: 52
Points: 45,485, Level: 52 Points: 45,485, Level: 52 Points: 45,485, Level: 52
Activity: 21.6%
Activity: 21.6% Activity: 21.6% Activity: 21.6%
Thanks: Gave 378, Got 854
how long should it take to import AVCHD clips? Tryign to import one now which is 13 minutes long and its saying it'll take 25ish minutes. Tried the little card reader that came with my card (sandisk) and thats basically the same as using my camcorder directly.
does imovie08 add any overhead? Is it just copying straight off the card first or converting to AIC on the fly which might cap its speed?
Just wondering in case I can get a dramatic speed up using a particular USB2 card reader to get the most out of it. Its a class 4 or 6 card, can't remember which, which should have decent read speeds. You'd think it could do more than 8Mb/s anyway
Old 30-05-2008, 11:02 AM   #2
17,460, Level: 32
Points: 17,460, Level: 32 Points: 17,460, Level: 32 Points: 17,460, Level: 32
Thanks: Gave 104, Got 241
Re: how long should AVCHD importing take?
If you use the card reader and copy the clip from your card to your PC then you'll know what the problem is.
If it still takes ages it's your editing programme, if it doesn't, it's the copying fro cam to PC.
Old 30-05-2008, 11:06 AM   #3
4,845, Level: 16
Points: 4,845, Level: 16 Points: 4,845, Level: 16 Points: 4,845, Level: 16
Thanks: Gave 6, Got 1
I find that on my PC, with the SDHC card directly into the PC (sony media centre) it takes roughly 3 minutes per GB. That is roughly though.
If i do it through the camera via USB it is about the same, maybe slightly slower but not dramatically.
Old 30-05-2008, 12:08 PM   #4
Mr Lazy's Avatar
5,051, Level: 16
Points: 5,051, Level: 16 Points: 5,051, Level: 16 Points: 5,051, Level: 16
Thanks: Gave 101, Got 148
Always worth copying to the PC first in case the card reader decides to corrupt the card for whatever reason (I've had this happen and lost two photos).
I find that when copying from a Kingston Class 4 card in my HF100 it peaks at 6MB/sec and averages around 4MB/sec ie. slow. When using the internal card reader in my laptop it is 1.5MB/sec ie. painful.
So I bought one of these:
http://www.sandisk.co.uk/Products/It...SB_Reader.aspx (bit hard to find)
which manages 12MB/sec (might be more with a Class 6)
though I also borrowed one of these to try:
http://www.sandisk.co.uk/Products/It...derWriter.aspx
and got 10-11MB/sec
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 1:30pm. Prices include delivery.
[IMG] code is Off
