| Re: Std.definition or High definition would there be a difference?
3 CCD high def camcorder.... they are probably talking about the Panasonic SD9 or SD5. The SD5 especially has been going for the bargin price of £350 on Amazon.
I agree with Senu; it depends. You probably won't see the benefit of the HD today. But it still could be worth it, as some day you'll have a HDTV.
It also depends on the sort of SD TV you have. If it is an CRT and can't accept a HD signal, then it's as Senu said; S-video is good, composite not. I have a SD plasma, but it accepts HD signals; and even though the screen is SD, HD footage looks great on it (better than SD).
