Originally Posted by niki_n Thanks very much for your response.
The manual supplied with the camera indicated I should be able to download via the USB cable without any issues, but with Windows 98 there would be no sound, W2K and WXP were compatible.
And like I said - the movie downloads to my PC as per the instructions - but no sound.
I've not heard of a Firewire card before, I'm in NZ, do I just talk to my local PC store about this? |
Yes ,
You may already have firewire socket on your PC and just need a cable. It is not a UK or US specific thing and has been around for a long time . Im sure it is alive and well In New Zealand
The card only comes into play if you need to add firewire capability to the PC
It is also called I-link, IEEE1934, DV link all meaning the same thing
The socket on the camcorder will be labelled i-link ( means the same thing)
Some MiniDV camcorders have the capability to download, stills, lower quality video, and rarely DV video with USB, but the defacto standard is firewire.
The reasons are part historical , and partly because firewire is a better for DV Video transfer than USB 1. The data on the tape is not downloaded as such but is streamed ( there is a lot of data on that tape) and a steady throughput is needed for accurate capture to PC
Also many video editing software expect DV video to be "captured" by firewire and the protocol supports control of the camcorders transport , from the PC. You can also use it to return edited material back to tape as it happens
