| Re: Recording Modes HG/HN/HE - differences in quality?
VBR simply gives you better quality for the same amount of bits than CBR, by using less bits when there is little motion/difference between frames, and more when you need them.
The highest quality setting uses a high bit rate, so doesn't need VBR. VBR is only needed when you what a lower bitrate. HN and HE use lower bitrates.
The 1440 vs 1920 you are unlikely to be able to tell. But because of the lower bitrate, you may see more "artifacts" (bits that don't look quite right!) with the lower quality settings, especially if a lot of motion.
