Originally Posted by koolpc Thanks. I have read the thread but still confused mate!!
Should i get another MiniDV then? Would HDD be easier / better? Is SD out of the question? |
HDD will be easier for download to PC and faster. It will have the files already made as mpeg2 , and clips may be easier to use selectively before down load
If no editing is required it is easy to get to DVD and no further encoding is required
However if extensive editing is required, it may suffer quality loss far more than DV AVI from tape , as it wil get rerendered several times. If you dont mind this, or editing wil be minimal.. go for it
SD is a variant not out of the question but seems to a a Panasonic preference
It is
not quality that differentiates them , just the fact that SD as a removable media a bit like tape( in that sense ) but with the advantage of fast download like with HDD) disadvantage is that a HDD will take a lot more and there is no need to buy several cards for reuse
The advantage of tape is that pound for pound at the budget level , the starting video quality is better. It is only latter that the gap closes up
I made remarks about tape to say those who use it and like its quality don't find the advantages of HDD and SD to overide them at this time.
This is not to say HDD / SD are not as good but that only at mid range price level
One of my favourites is the Sony SR 190 ect level that HDD is a worthy contender . The cheaper SR 32 ect.. I would avoid
However for some , any potential drop in quality is minor compared to the sheer convenience of a tapeless recording media with fast and "easy " PC download
You have to make you mind up what your current thinking is
If you name a particular model , you will likely get opinions on it.
