Originally Posted by NiceNick
No problems if you're viewing HD on HDTV or PC
Playback on DVD (SD) may present a problem if the equipment is not dual standard or NTSC compatable, as any conversion to SD DVD will be in the NTSC format so may not be compatible with some AV equipment
If you wish to edit your footage then it will have to be in the NTSC format and not PAL, NTSC HD is shot at 30fps, PAL HD is shot at 25fps
If in the future you wish to upgrade to a new cam and use footage from this cam then it would be advisable to purchase another NTSC cam as the formats are not compatable.
