Originally Posted by ensyed I am looking to buy a harddrive or flash based HD camcorder next month. I was reading reviews on CNET and in one review they said that they have yet to see a AVCHD based camcorder produce as good video as HDV based camcorders.
Is this true in your experience? |
Notice
*Informed Opinion* not Gospel truth : No flaming pls just state your own opinion:
AVCHD is " a work in progress". It is capable of looking better than HDV but only ( IMHO)when the camcorders are able to get rid of motion artifacts and the nth degree of low light issues. Most of the sample shots would be in ideal lighting and minimal movt situation, As it happens it is a consumer oriented format though for all that but a very impressive one.
The amount of compression involved means the computing power of the camcorders needs to be better but they have to remain affordable: that is the manufacturers challenge
I have used the Canon HG 10, Sony SR7 and had a play with the SR11. ( all HDD based current AVCHD models) Im well impressed with them.
I have one or two "decent" HDV camcorders :and have used one or 3 whose cost and a small family car are similar
There is no AVCHD at that Semi Pro level for a fair comparison: HDV obviously wins in that sector. HDV has been used Professionally
In the consumer sector
my personal view is that AVCHD is as good and can ( when encoding bitrates can be upped sucessfully) get even better but despite rave reviews of the SR11/12 Canon HF10 /100, A good HDV camcorder will not be bettered effortlessly ATM
I think that direct file access, easy no real time transfer, no need for old tapes , and longer recording times coupled with rather impressive Video quality can make a strong case for HDD AVCHD based camcorders especially as tape models are dwindling
but
ATM, tape is fighting , ( albeit hard) to keep the " best quality" honours, It will be a while ( if at all) before AVCHD is embraced by Serious enthusiasts, SemiPros Pros even if they seek alternatives to tape , and an "ageing" mpeg2 format
Also it looks like hard drive based cams can hold 20-30 hrs of video while flash based 1/2 hr or so. Is this true? Then is it more convenient to have the hard drive based ones?
Not so , that is a generalisation. Although the HDD based ones have large 80Gb models which can hold a lot of video. You can get up to 16Gb cards which will take way more than 1/2 hr even at highest encoding bitrate..
HDD vs Card is a matter of preference rather than quality. Some can record to both ( I believe)
I am looking at Sony and Canon. Which one is generally produces the best looking video?
Neither or either ( take your pick) .. and dont forget Panasonic
I am planning on transferring the videos to my htpc for playback until I invest in a bluray player/burner.
Sounds about right
