Originally Posted by Ahmed Senu, I've looked up a few threads on the discussion digital8 vs miniDV, and you have said in some of these threads that it's basically "more of the same" - ie there's very little difference between the formats - so I'm a bit confused when you said, in the post above, I need to change to digital and soon : I thought (as the name implies) digital8 was digital? |
Apologies, digital 8
is digital ( recorded on hi8 tape) and as implemented on some of the better D8 camcorders virtually identical to MiniDV
However some latter MiniDV models are so much better that they made D8 look a tad less great, This is also partly because many of the latter D8 models were not of sterling quality.
Are you saying this because it's an older format and the availability of digital8 machines will become scarce or for some other reason? (also, I am using Hi8 tapes to record digital8 footage).
I have one myself and if I use it I tend to transfer the footage fairly quickly just in case it malfunctions
The problem is that they are no longer in production and any models you buy now will be second hand. This means that if you do get a good one, and accumulate a collection of D8 footage, should yours malfunction , break be stolen ect. You may well have no means of playing them again.
Although even MiniDV models are far fewer now . I imagine it will still be around for a little while yet as it has been a longer lasting and multi brand format ( not Sony only)
If you have any D8 footage, or even Hi8 , now would be a good time to get them onto a HDD say as mpeg2.. before you are no longer able to play them due to the simple fact of absolutely nothing to play them with
