Originally Posted by Andy98765 I think you are missing something. It is easier to edit on a PC IF you have the right connections and Software. |
I agree entirely ..
what you are struggling to do in-camera is infinitely easier with more control on a PC
I suspect you will wonder why you didnt do it on the PC when you find out how easy it can be
The only connection you need is a USB cable. Software abound. The JVC does tend to come with Cyberlink ( which I ( personally) dont rate much but is "free" with the camcorder and usable)
Otherwise Download Sony Vegas Movie Studio 8 Platinum ( or similar) as a trial version and see how much less fiddling you would do
In Camera editing...??.
, Give it a miss!
