Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Samsung SMX-C10
Panasonic HDC-SD200
 More...Prices updated November 24th at 10:30pm and include delivery.
buying advice for camera grismtrax Digital Photography General Chat 4 25-08-2007 10:23 PM
Advice on buying a camera chrism_scotland Digital Photography General Chat 48 04-02-2007 12:10 PM
Digital camera buying advice around £240 kbfern Digital Photography General Chat 5 24-08-2005 9:16 PM
I have never bought a camera before and just want advice before buying one crazzy kopite Digital Photography General Chat 7 11-06-2005 4:35 PM
In car recording (Camera Buying Advice) sandys Camcorders and Video Editing 0 22-04-2004 11:01 AM
Old 07-04-2008, 2:16 PM   #1 (permalink)
Ewan154's Avatar
Thanks: Gave 313, Got 31
Question buying first video camera? advice pls/
Looking to buy my first video camera soon. I wantsomething that would be easy to use. What should I be look for when buying my first cam?
http://www.amazon.co.uk/Sony-DCR-HC5...7577275&sr=1-6
http://www.amazon.co.uk/Sony-DCR-DVD...7577275&sr=1-6
Tv: LG 32LC3R -lcd|sky +|DVD player:Toshiba SD330E| Amp:SonySTR-DE695S|Speakers: Mordaunt short,MS302,MS304,MS308 subwoofer|Consoles:xbox 360,PSP,PS3 40gb|Panasonic DMR-EZ27 dvd recorder||OPTOMA HD700X PJ|Panasonic DMP-BD35EB-K blu-ray player.
Ewan154 is offline   Reply With Quote
Old 07-04-2008, 2:49 PM   #2 (permalink)
redsox_mark's Avatar
Thanks: Gave 90, Got 749
Re: buying first video camera? advice pls/
By the links you gave, I assume you are looking at an entry level type (sub £200) model.
Any consumer camcorder is easy to use. If you want to watch your video from DVDs, then the DVD models have the one advantage that you can shoot, finalise the dics, and play them. But that is offset by some limitations and possible issues if the disc fails, see here DVD vs MiniDV
In this pricerange, miniDV tape models give the best quality, and are reliable and easy to use. To create a DVD you then need to use a PC (plus software, and DVD buner), or use a set top DVD recorder (the easier way).
Mark
redsox_mark is offline   Reply With Quote
Old 07-04-2008, 3:11 PM   #3 (permalink)
Ewan154's Avatar
Thanks for the reply I really fancy the Sony DCR-HC51E Mini DV Handycam. Would this be ok?
Would I be able to put plug this into my telly?
Old 07-04-2008, 3:30 PM   #4 (permalink)
Yes, you can simply connect the camcorder to the TV. And yes, the HC51 is a decent camcorder for the price.
Mark
Ewan154 (07-04-2008)
Old 07-04-2008, 8:49 PM   #5 (permalink)
Thanks: Gave 425, Got 2,080
Hmm.. let someone else buy the DVD model ... *coughs and hurrys out of room*
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
advice, buying, camera, pls or, video
[IMG] code is Off
