| Re: DV Transfer - Dropped Frames - Help
An external drive , A separate partition on the same system or separate internal HDD ( from the system ) would be OK for capture.
However dropped frames may also occur on any of them if the drive is fragmented, or there are too many programs running in the background ( Antivirus, anti spyware, ) or any "monitoring" programs that load up with windows.
If you want to specify a " default" capture folder, open up the capture program ( I have Ver 6)
under the menu items
select:options
Preferences
then
open TAB: Disc management
You can then browse to any Capture folder you wish: you can put more than one
