Just researching a new camcorder purchase and I've been swayed by the opinions on here that its worth stumping up the extra cash for a high def machine!
I've decided on Mini DV because a hard drive has a limited capacity (going on honeymoon and dont want to run out of space), DVD doesnt seem to be recommended for high-def capture on here and the memory sticks are stupidly expensive (£100+ for a 16gb stick that holds approx 4hrs of footage - is this right???)
Anyway, with the above reasoning, I've heard a lot of people recommend the Canon HV20 but I was wondering how the 2 Sony high-def models stack up?? (the HDR-HC5E & the HDR-HC7E)
Held the HV20 in a shop yesterday and it looked very nice but felt a bit heavy - is this to be expected with the tape mechanism on any high-def model?
All of the above models can seem to be had for between £500-£550 but I'm gonna be wanting a few extra's such as memory stick for still's, extra battery (longer life if poss.), case etc so does anyone know which one might be the best to go for including these??
Also, I'm assuming the standard Mini DV cassettes are fine for high-def capture? but I've also seen that you can get specific HD Mini DV cassettes - are these recommended??
ANY help on the above is gratefully received as I'm a complete noob when it comes to this! (plus any other makes/models anyone wants to recommend, but £550 is the absolute max budget!! - I've got a wedding to pay for!
Also any recommendations on where I can get the best deal on any of these?? (or e-tailers to avoid??)
Thanks...
SteveP
