Originally Posted by redsox_mark Yes, the HV20 is (arguably) the best sub £1000 high def option for quality. (The HV30 more of the same, with a colour change). And yes, it takes the same miniDV tapes, but records in HDV/MPEG2. Like all HDV cams, it can also record in DV if you want. You can also record in HDV and have the camcorder convert to DV.... |
Is it possible to record in high-def and "convert" it to standard def (as I dont have a high-def TV yet!) but also keep the original tapes and use the better quality when I have the TV to use it on?
Also, I'm assuming the Mini DV tapes are a standard length still? Or are they effectively shorter because the higher quality takes up more room/space?
(can you still use the "LP" option that most camcorders give?)
Sorry for all the noob questions but the more I think about it, the more I'm gonna want to look back on my honeymoon in glorious high-def!!!!
SteveP
