Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 23rd at 9:30am and include delivery.
transfering vhs camcorder tapes ljab Camcorders and Video Editing 2 07-05-2006 1:21 AM
Hi8 Camcorder tapes (8mm) - Problem cherc2005 Camcorders and Video Editing 5 15-06-2005 9:38 PM
help want to copy to my camcorder from old camcorder tapes through my vcr ferryboat Camcorders and Video Editing 4 26-05-2005 11:33 AM
Looking for old camcorder tutorial tapes funkanova Camcorders and Video Editing 3 10-05-2005 12:28 PM
Copy from the camcorder tapes to PC obrutau Camcorders and Video Editing 12 21-02-2004 9:22 AM
Old 27-01-2008, 12:04 PM   #1 (permalink)
Thanks: Gave 7, Got 2
8mm camcorder tapes to DVD
I have several 8mm analogue tapes that I intend putting onto DVD with some minimal editing using a DVD recorder that has the option of manual recording modes. For general use I have it set to get 3 hours on a DVD, instead of the 2 hours Standard Play (SP) setting.
If I leave it at this setting I can get two 8mm tapes on a DVD as they run for 1.5 hours each. My question is what recording setting do I use for
a) 8mm and
b) Digital 8
camcorder tapes to get optimum quality without having unnecessarily high settings?
Kopil is offline   Reply With Quote
Old 27-01-2008, 1:57 PM   #2 (permalink)
Thanks: Gave 6, Got 109
Re: 8mm camcorder tapes to DVD
a) 8mm and
b) Digital 8
i dont know why you are worried about using too many dvds i would only put 60mins at xp per disc imaterial if it is fom 8mm or digital 8,if you must use less discs 8mm could record sp[2 hours on disc]but digital 8 unless you want lower quality i would only ever use xp.
chrishull3 is offline   Reply With Quote
Kopil (27-01-2008)
Old 27-01-2008, 9:31 PM   #3 (permalink)
Thanks: Gave 425, Got 2,078
Agree ,
3 hrs per DVD is stretching things a bit and for D8 ( which is essentially MiniDV on a Hi 8 tape) I would stick close to the 1 Hr limit
If you have a setop DVD recorder with HDD you can put 90 min of D8 on one DVD bearing in mind that the settops use a variable bit rate encoding whichever setting you use. They just adjust this by selecting different max an minimum bitrates
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is online now   Reply With Quote
8mm, camcorder, dvd, tapes
[IMG] code is Off
