Originally Posted by scooby do Ok done it all within ulead and the results were not as good as my botched attempts with canopus ulead then DVD Shrink. Trying again with a different variation which is canopus to m2p then U lead for authoring. Will let you know. My set up is critical as I have a sony KDS 55a2000 which is probably miles to big for the quality of my camera |
Ulead Movie Factory for authoring..
not VideoStudio
Brian 110507 is the Video Studio man if you wish to get the very best out of it
A bit more on that
Although unlike you, I use DV AVI as starting material,
For video encoding: I also have Canopus procoder 2, and have tried TMPGenc. Cinemacraft basic and MainConcepts Mpeg Encoder
For Editing and integrated DVD authoring: Pinnacle Studio Adobe Premiere Elements, Ulead VS10 and Sony Vegas ( Movie Studio and full version as well as Pro Show gold for outputting Slideshows to mpeg2
For Standalone DVD Authoring : I use Ulead Movie Factory , Movie Workshop ( much better) and DVD Architect
There is no right or wrong way but it is important to realise the concept of logical workflow Ie
1) Start with best quality material DV AVI in this case
2) Realise that DV AVI is not only the best starting material, it is also virtually unaffected by multiple rerenders and reencoding. Mpeg is affected and each subsequent copy will exhibit generational loss of quality ( a bit like copying a dubbed audio cassette tape and comparing that to copying a CD which is almost identical to the original)
3) Avoid converting from DV AVI to mpeg
until you've finished the editing
4) Definitely don't convert from mpeg to DV AVI unless you cannot edit mpeg as mpeg.
5) Leave the creation of
VOBs to the DVD authoring software ( unless you are absolutely certain you can import them as such%2
