Is the front mic enough for this kind of material?
I'm looking for a good budget camcorder to make some hardware reviews where I point at the object I'm inspecting, and speak either behind or under the camera with only my hands showing like this one:
A few salesmen (in different stores) recommended the JVC GZ-MG130, as it's the best within my budget available here (under $530 US), but it only has a front mic, and no mic port.
Do you think it would do the job?
Also, if there are any specs I should look for for recording this kind of videos specifically, please let me know.
Re: Is the front mic enough for this kind of material?
The mic will work, but for that kind of work you'd be better off with one with a mic input, you could then wear a lavalier (tie clip) mic.
Or, the other option would be to record the video first, and replace the sound with a separate audio track (e.g. you could use a mic attached to your PC, or other device). If they aren't going to see you talking this will work well.
No I wouldn't pay an extra $420, though you can buy a better camcorder than the MG130 with a mic input for less money, if you don't mind DV tape. Are you buying in the US? Here I would suggest the Panasonic GS230, but that model doesn't seem to exist there.
