Originally Posted by CGR
From everything that I have read I can never work out if you can record to a card as there is always the impression that this is only for stills. |
That's correct if you are using a Video camcorder with the ability to take Photo's, generally these are usually "tape based" camcorders, however Solid State video camcorders or digital still cameras can capture video/photos to SD cards, which you can just pop into the USB port of the PC and transfer over.
Video cams take better video than photos and Digital cameras take better photos than Video, however if your video is intended for viewing on a PC only a good Solid State video cam or digital camera would IMO be good enough for the project.
Check out the Sanyo Xacti cams these are cams that can do a decent job of both
