| Re: sony hdr-hc5 or hdr-sr5
This is really a HDV ( tape) vs AVCHD (HDD) question
Start by assuming Video and audio Quality are quite similar, (tape is marginally better)
HDV capture is Firewire only
Im not sure what you mean by HDD codec not being 100%
As both are Hi def ..Yes on a suitable display you will get much better quality than SD DV but that (PC3) is a very good SD model IIRC. It may be that the SD performance of the HDV model will match and be definitely better than but not be a big step up . As for the HDD model I imagine its Hi def downconverted in software to SD will not be better .. but not worse depending on how the downcoversion is done
How you decide you will be whether you feel the advantages of tapeless recording are worth the current ( teething issues: Playback, editing and need of decent Spec PC and limited output options ) of the AVCHD format which may be ( to you ) non issues..
Both Hi def formats currently suffer by not ( Like DV) having a readily available playback carrier like SD DVD video but they are the here and now of video recording
Certainly having say a PS3 and an HDTV will help you realise how stunning Hi def can be but it isn't quite as easy to enjoy as Hi def by just , like with your PC3 shooting and burning a DVD to play
