| Re: Audio Dubbing on HiDef Camcorders 1. Are there any models which allow audio dubbing afterwards or must that be done with a PC?
As far as I know, only with HDV models when shooting in DV mode (e.g. the Canon HV20). 2. If I make a mistake in recording a few seconds of footage, will the non-tape models allow me to 'rewind' a bit and restart? Or must I edit the mistake out later?
With a non-tape model, each time you stop the camcorder it creates a new clip (file). So there is no need to rewind, you just stop, then start again. You can delete the unwanted clip. 3. Can I archive the HiDef footage to a large computer disc and wait until HD DVD recorders come down in price and make HD DVDs? What problems will I encounter?
Yes you can. Depending on how much you shoot you'll need a lot of disc space, and make sure you have a way of doing backups.
