| Sony DCR HC20E Not Charging/No Battery Info
Got the camcorder out a few days ago as the missus needs it for a Uni project.
Checked the two batteries using the battery info button - no probs both fully charged.
Went to get it today to find a tape for her opened it to insert a tape - nada.
Looked at the on off it was in a weird position though bugger it must have been on and the big FP70 has gone flat.
So put the smaller FP50 in - nada, so thought ok maybe thats flat too.
Plugged in the mains adapter - it powers up I start checking the tape then after a while it starts switching itself from play to camera mode.
I'd had this once before where I mistakenly left the power brick turned off at the wall when transfering footage to the PC.
So checked the psu - seems ok as the camcorder powers on with only the adapter plugged in.
So I go to check the batteries but the battery info doesn't work with the camcorder turned off, either with the adapter plugged in or not.
Plus I noticed that the charging light is not lit.
I thought at first the battery was charging even tho its not lit as I left the FP70 in with the adapter plugged in and now it will turn on with only the FP70 in.
Also both the FP70 & FP50 show battery charge status when the camcorder is on in either camera or play mode - but the battery info button still won't work.
All other buttons on the camcorder seem fine including the touchscreen.
Any thoughts or ideas of whats wrong and how I can fix it?
