| Ulead VS11.5 and Panasonic AVCHD files
I've now rendered the same set of clips that I mentioned a few posts ago using VS11's 'AVCHD' disk setting rather than the 'HDDVD' setting.
The HDDVD choice took 42mins to render, and came out as a 22Mbps Mpeg video on the DVD, as reported by PowerDVD Ultra. The disk structure was very simple, like an ordinary DVD with a single HVDVD_TS directory containing a number of 1GB video files as .EVOs.
The AVCHD setting took over an hour to render the 18minutes, and PowerDVD reports it as MPEG4 running at about 8Mbps. Again, I can't explore the disk on one PC, but on the one where I have the UDF drivers installed, it has a BLuRay directory structure with a top level BDMV directory, and the somewhat complex empty structure under that, 'MovieObject.bdmv','index.bdmv' and then the AUXDATA, BACKUP,BDJO,CLIPINF,JAR,META,PLAYLIST, STREAM dirs. There's only one file in the STREAM dir, a 1.3GB .m2ts file. The disk will not play as a drag n' drop on this machine, since PowerDVD sees it as a BluRay disk and tells me I have an incompatible graphics system. (No AACS of course on this laptop). But browsing into the STREAM dir, and then dragging and dropping the .m2ts file directly on to PowerDVD, it plays OK. It may be that this is the ability that has been removed in versions of PowerDVD later than 3319a. But I'm not updating to find out!
It will drag n' drop OK on the other machine, which does have an AACS video card (ATI 2600Pro)
Edit: one thing I've just noticed is that this version produced with the AVCHD setting has preserved the Dolby Digital track, whereas the HDDVD setting produced a PCM stereo track. There are customising settings that I haven't tried yet that may fix this.
Edit edit!: There doesn't appear to be a setting in the HDDVD disk producer to allow the generation of the 5.1 track for some reason: it just produces PCM. But Dolby Digital works in AVCHD mode.
