Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 23rd at 4:30pm and include delivery.
pioneer 508xd or 5080xd? biketrader Plasma Televisions 7 22-10-2007 5:40 PM
Settings for Pioneer 508XD - Goody Two Shoes Plasma Televisions 1 11-10-2007 2:47 PM
Onkyo 805 with Pioneer 508xd gingerling AV Amplifiers and Receivers 1 23-09-2007 2:56 PM
Pioneer PDP - 508XD Goody Two Shoes Plasma Televisions 4 03-09-2007 12:27 PM
Pioneer 508XD settings? adamphilpott Plasma Televisions 1 30-06-2007 11:45 PM
Old 20-12-2007, 10:31 PM   #1 (permalink)
HDR-SR8 hdmi connecton to Pioneer 508xd
have connected my SR8 to pioneer plasma via HDMI but have no picture playback. can anyone tell me where i might be gong wrong
buttons129 is offline   Reply With Quote
Old 20-12-2007, 11:25 PM   #2 (permalink)
Thanks: Gave 6, Got 109
Re: HDR-SR8 hdmi connecton to Pioneer 508xd
does the lead you are using on the pioneer play with other equipment[dvd player ps3 etc]if so the problem must be with the cam,i dont know about your sr8 but my fx-7 plays out of the hdmi but will not play out of component at the same time but yours does not have component unless i am mistaken just try without any other lead ,it sounds most likely a lead or
socket problem.
had a look and it seems your cam does have component .
http://reviews.cnet.co.uk/camcorders...9291434,00.htm
http://www.tech.co.uk/gadgets/digita...w/sony-hdr-sr8
chrishull3 is offline   Reply With Quote
Old 21-12-2007, 10:24 AM   #3 (permalink)
cant try the lead with anything else as its mini HDMI on the camcorder end with normal HDMI into the plasma. the mini end i think is called HDMI 1.3 and is next gen camcorder connection (so sony says!) wonder if that has a bearing on it
Edit: checked the Pioneer web site and it says 1.3 Ok! cant be that then.
Old 21-12-2007, 10:26 AM   #4 (permalink)
Thanks: Gave 98, Got 101
Do you have to enable HDMI in Sony menu ?
lurcher is offline   Reply With Quote
Old 21-12-2007, 10:43 AM   #5 (permalink)
in the SR8's menu you go through a TV connection guide and select the HDMI.
also another option is to playback through cam and TV so i `think' i have gone through all the right options. swopped over the HDMI connection with my PS3 so both sockets on the plasma are fine. might take the cable and cam to a sony centre and see if they can test it
Old 21-12-2007, 10:46 AM   #6 (permalink)
I"ve got the SR7 connected in same way to a Samsung with no prob ( pity Sony dont supply cable ) , spose you"ve unplugged replugged etc ?
Old 21-12-2007, 2:53 PM   #7 (permalink)
Thanks: Gave 5, Got 11
Have you enabled the HDMI connection on the input you're using on the Pioneer? I had the same problem until I done this.
Pete
AV Gear:Panasonic TX-37LZD80 LCD | Pioneer DVR-LX60D DVD Recorder | Panasonic DMP-35 Bluray |Humax Freesat HD | Xbox360 Elite
Zebadee69 is offline   Reply With Quote
Old 27-12-2007, 7:46 PM   #8 (permalink)
late reply due to christmas cheer. have tried HDMI options on the pionerr. will be popping the camcorder into a sony centre to have it checked out and will post results.
508xd, connecton, hdmi, hdrsr8, pioneer
[IMG] code is Off
