| Re: Sony Camcorder mini DV downloaded to PC
Maybe the laptop does'nt meet the minimum specs for doing video work .Laptop hard drives dont run at 7200rpm like PC ones ,they run at 5400rpm , so there might be a problem there .Also , you do need a fair bit of RAM , so unless your laptop has a dedicated graphics card ,this maybe using some of your memmory. If you have lots of other things running in the background of your laptop .ie anti-virus ,anti-spyware and other's using resources ,this might also be a problem.
To be honest , I would'nt know what the minimum specs are for video editing on a laptop and have never heard of problems unless it's an old model . I have a very old Compaq Armada m300 I use for my accounts , it's ideal for typing letters and such but trying to play DVD through the external DVD player is a no-no and is so blocky it's unwatchable ,this is very low spec and would be the cause of poor picture quality .
You dont say what model of laptop you have .
