If you are getting a B&W picture then my guess is that you are connecting your 8mm camcorder to your VCR with an S-Video lead. This will not work as a VCR can not receive an S-Video signal correctly. Use the yellow phono socket (composite) to connect to the VCR.
Why are you connecting via your VCR? Why not go directly from 8mm camcorder to DV camcorder, this will enable you to use the S-Video (higher quality) connection or even if useing composite you will still get better quality as there is one less piece of equipment in the path to degrade the final recording.
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
