Light tripod OK for smooth pans?
Old 27-11-2007, 8:19 PM   #1
4,606, Level: 16
Points: 4,606, Level: 16 Points: 4,606, Level: 16 Points: 4,606, Level: 16
Thanks: Gave 1, Got 2
I want to get a decent tripod that will give smooth pans and I am immediately drawn to the velbon dv-7000. This seems to be well recommended and is currently available from jessops for £63, but the 3.5kg weight sounds mighty heavy to carry around. The Velbon CX range still have fluid heads and are much lighter, but does the lack of weight compromise the panning ability? Does anyone have any experience of these lighter tripods? It will be used with a Canon hv20. Thanks.
Old 28-11-2007, 8:57 AM   #2
5,724, Level: 17
Points: 5,724, Level: 17 Points: 5,724, Level: 17 Points: 5,724, Level: 17
Thanks: Gave 15, Got 48
Re: Light tripod OK for smooth pans?
I don't know about the Velbon CX tripods, but I use a relatively cheap Jessops TP323. I find it great for a light cam, and very smooth, but it isn't fluid filled, and not really in the same league as the DV-7000 (although I really do find the 'lower league' all I need for a light cam!). I've also got a Velbon monopod which is fantastic (but doesn't have pan). You're probably best to try and get to a shop to try them and see how they feel to you...
Old 28-11-2007, 9:45 AM   #3
redsox_mark's Avatar
22,297, Level: 36
Points: 22,297, Level: 36 Points: 22,297, Level: 36 Points: 22,297, Level: 36
Thanks: Gave 90, Got 749
The CX is pretty good for a cheap lightweight tripod. There is a tradeoff; the heavier DV-7000 gives you a more solid base, so less likely that you get any non-smooth movement (i.e. not having the base of the tripod move a bit when you pan). You can get both strength and less weight in the legs by going with expensive carbon fibre legs… but in cheaper models you will trade off some stability for lower weight.
Old 28-11-2007, 12:55 PM   #4
4,606, Level: 16
Thanks for your input guys. I had a look in Jessops yesterday and (as mentioned elsewhere) they didn't have much variety. If I order online and go for store collection, can I choose not to buy after looking it over?
Actually this may be a moot point - the DV7000 seems to have gone up to £99 now, should have gone for it last night. Damn.
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 13th at 1:30pm. Prices include delivery.
[IMG] code is Off
