Connecting Camcorder to PC
Old 26-11-2007, 11:37 AM   #1
Meee123
Posts: n/a
hi,
im trying to find a cable that will connect my camcorder to my PC. Unfortuanatly my PC has only Video AV Connection and a TOSLINK connecter.
the camcorder on the other hand hasnt got a TOSLINK digital connector or a 3.5mm jack to make the digital connection.
it has however got the av connection. this brings me back to only being able to have the video connection, i really need the sound aswell so if any one has any ideas how to get round this problem maybe a usb to av audio connector, ur input would be greatly appretiated.
the camcorder has got a s video connector but i have found no s/pdif cable that can give me audio and video. and according to a local electrician i would still need someway of connecting sound to my pc even if i used the s/pdif connection.
thank you.
Old 26-11-2007, 11:54 AM   #2
redsox_mark's Avatar
22,297, Level: 36
Points: 22,297, Level: 36 Points: 22,297, Level: 36 Points: 22,297, Level: 36
Thanks: Gave 90, Got 749
Re: Connecting Camcorder to PC
What camcorder is it? (Make/model)?
Old 26-11-2007, 1:18 PM   #3
Meee123
Posts: n/a
oh sry i thought i put that on.
Make:Sony
Model Number: CCDTR718E
Old 26-11-2007, 2:29 PM   #4
22,297, Level: 36
Ok...it's an analogue (Hi8) cam, so using Firewire is out..
The camcorder has S-video out as you have said; then from the av jack you use the av cable which has both composite video (on one phono plug) and mono audio on the other.
Normally then the way to connect to your PC to capture video is to a video capture card/device or tv card of some sort. This solution captures as DV
http://www.dv247.com/invt/23453
Or there are cheaper options like this, which generally capture as MPEG2
http://www.maplin.co.uk/module.aspx?...064&doy=search
Old 26-11-2007, 2:51 PM   #5
Meee123
Posts: n/a
hi,
thank you for your replies. i have since found a much cheaper option where i can get sound and video onto my computer from the camcorder.
http://cgi.ebay.co.uk/Dazzle-Video-C...QQcmdZViewItem
this happens to have svideo connections aswell as the AV connections.
still its 60 quid in most e/retailers so hopefully ill get it.
once again thank you for the help
Old 26-11-2007, 2:54 PM   #6
22,297, Level: 36
Yes, that will do it as well.
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
6 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 12th at 8:30pm. Prices include delivery.
[IMG] code is Off
