Best way of fading between two clips?
Old 17-11-2007, 7:38 AM   #1
2,776, Level: 12
Points: 2,776, Level: 12 Points: 2,776, Level: 12 Points: 2,776, Level: 12
Thanks: Gave 9, Got 0
Question Best way of fading between two clips?
I have the following timeline:
<clip1-8secs><clip2-3secs><clip3-3secs><clip4-3secs><clip5-20secs>
I wish to have a short fade between clip2 and clip3 but when I try to use the Cross Dissolve transition in Adobe Premiere Pro CS3, I get a message stating "Insufficient media. This transition will contain repeated frames."
Any idea how I can solve this?
Old 17-11-2007, 9:07 AM   #2
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Re: Best way of fading between two clips?
In general most video editing programs need a minimum amount ( duration) of footage to create a transition between clips, and will give the same message you got from Premiere if the clips are deemed to be too short
The transitions are created by merging elements of the outgoing and incoming clips and are themselves of a minimum duration otherwise they will be so brief you may not notice them
As such I feel a 3 second clip followed by another 3 second clip ( such as you intend) may not lend themselves easily to a fade in many programs
What happens in some instances is that the clips are timestreched ( or repeated to allow easy creation of a transition
Another method is to use a still( whose duration you can prolong) instead of one of the (short) clip
HTH
King Mustard (17-11-2007)
Old 17-11-2007, 9:18 AM   #3
2,776, Level: 12
Question Re: Best way of fading between two clips?
HTH
Would you suggest I use Blend from the Effect Controls panel?
Old 17-11-2007, 10:20 AM   #4
redsox_mark's Avatar
22,297, Level: 36
Points: 22,297, Level: 36 Points: 22,297, Level: 36 Points: 22,297, Level: 36
Thanks: Gave 90, Got 749
I've used short clips with very little overlap on the cross fade (e.g. 5 or 6 frames, 1/4 of a second or so) in Vegas and never had any issues. Agree with senu that having lots of short clips with fades between them may look hectic and best avoided, but I've never come accross a technical limitation.
Old 17-11-2007, 10:42 AM   #5
47,154, Level: 53
Activity: 2.7%
You could.. as Mark implies, the ease of ability to do fades with very short clips could be program specific.
I also find it very much easier ( almost childs play) to do fades in Vegas than in Avid Liquid. Liquid is not shy in warning you that "You do not have enough material for a transition/effect " If it feels the transition or transition point are "invalid"
My familiarity with Premiere is getting rather faded now TBH although I still dabble with Premiere Elements ( Im "playing" with ver 4 ATM ) from time to time
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 11:30am. Prices include delivery.
[IMG] code is Off
