Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 4:30pm and include delivery.
compression sachin Camcorders and Video Editing 1 30-09-2007 2:41 PM
Sony HDR - HC3 - Standard tapes or hd tapes? chunky28 Camcorders and Video Editing 10 06-01-2007 7:13 PM
Compression? pvt.petey Projectors 7 19-08-2005 11:54 PM
Can't record coded dvd/tapes or none PAL tapes on the LG DR4810 reevestim7 Blu-ray and DVD Player Multiregion Hacks 0 26-09-2004 4:51 PM
DVD compression pcpaz Computer Systems 2 06-11-2002 5:55 PM
Old 13-11-2007, 4:57 PM   #1 (permalink)
AngelEyes's Avatar
Thanks: Gave 243, Got 538
DV tapes to HDD, best compression method?
I am using Premier Pro 2 to backup my DV tapes to HDD, at the moment I have them all saved as what I assume is uncompressed AVI. The files are fairly large, around 14GB per hr tape.
I used Premiere in the past to downsample a video to an mpeg but the quality was pants tbh.
What is the best compression metho to use that will not reduce the video quality visibly?
Ideally I would like something that will playback in Vista Media Centre but I am assuming as long as I have the correct codec installed this will be ok? I don't mind buying a codec if I have to. ideally it would be good to export in to the new format from Premier but I could always batch convert the videos afterwards in another app if I have to I guess?
One last thing, my latest Sony Camcorder saves it's files as AVCHD, can WMP or Premier use this format?
Many thanks,
Adam
| Fujitsu P42XHA58EB | BD HTPC | SkyHD | Squeezebox Duet | Beresford Caiman | Onkyo TX-SR876 | Cinepro 2K6 | Parasound Halo A23 x 3 & A52 | XTZ 99.36 & 26 | M&K CS22 & Xenon 36 | SVS AS-EQ1 & PB13 Ultra |
AngelEyes is offline   Reply With Quote
Old 13-11-2007, 5:14 PM   #2 (permalink)
Thanks: Gave 425, Got 2,078
Re: DV tapes to HDD, best compression method?
Originally Posted by AngelEyes View Post
DV AVI is compressed but not enough to make a difference
It shouldnt be DVDs have thier video files as mpeg2
You have to experiment but usually using an encoding bitrate nearer 8 Mbits/sec, is a case of "more". Encoding hardware and software are not equal though but there is no reason why the one that ships with Premiere should give anything other than great results
You probably wil already have it or be able to obtain it for free
WMP can play AVCHD if a suitable codec is on your system
Im not sure about Premiere TBH ( although i expect with 3rd party plugin you may) but I know Premiere Elements 4 among others can
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 13-11-2007, 5:23 PM   #3 (permalink)
Thanks: Gave 104, Got 242
You can use (a current version of - I have 7) Nero Showtime to play the files, and Nero Vision to edit them. Subject to having a powerful enough PC to accelerate the video of course.
rhubarbe is offline   Reply With Quote
Old 13-11-2007, 8:01 PM   #4 (permalink)
AngelEyes's Avatar
Thanks chaps, I'll have a play and see what results I come up with.
Out of interest I have CoreAVC Pro somewhere, is this a good encoder?
Would an Mpeg4 encoder do a better job than mpeg 2? If so any recomendations, there seem to be tons of codecs DivX, Xvid i wish i new what half of them were for
Adam
compression, hdd, method, tapes
[IMG] code is Off
