| Re: Panasonic HDC-SD5 or Sony HDR-SR7 ??
In terms of video quality I don’t think there is much difference. With the previous models (Sony SR1 and Panasonic SD1), the Sony generally had the edge in reviews; I’ve not seen a direct comparison of the SR7 and SD5. The Panasonic has 3 small CCDs, the Sony one large CMOS… the Sony should be better in low light, the Panasonic more accurate colours.
In terms of function, the main difference is the Sony is a HDD cam and the Panasonic uses SD cards. There are pros and cons there. I use tape (HDV) myself, but if I was to get a AVCHD cam I’m partial to the memory card based models, as I like the idea of no moving parts, and have some fear of HDD failure.
You are correct that the Sony has high resolution stills, the SD5 stills are at the 1920x1080 resolution only.
Lastly, don't overlook HDV cams, the Canon HV20 is better than any of the above in terms of video quality.
