Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 24th at 2:30pm and include delivery.
Old 23-01-2003, 2:42 AM   #1 (permalink)
Pierscoe1
Posts: n/a
DV-in on camcorder.. help please
Two questions..
I have a basic firewire card, which has a power-supply connector on it (like the ones for power to CD or HD drives)... do I need to connect this?? what is it for??
Also, how do I output from the computer back into my DV cam??
using premiere, and a JVC DVL767 (which has DV-in) ??
Many thanks, and please e-mail responses as I might miss a post here..
Piers Coe
Old 24-01-2003, 1:02 AM   #2 (permalink)
U don' have to plug in the power connector, it is only required is there is not enough power for the card. If the card does not work in premiere, u may have to connect it.
Can't comment on the 2nd question!
coolammo is offline   Reply With Quote
Old 24-01-2003, 5:22 AM   #3 (permalink)
First of all, make sure your camcorder it turned on and set to VCR mode (not record mode).
Then go to
File> Export Timeline > Export to Tape
Premier will then 'build' the movie and then control the camcorder making it record.
m@rk is offline   Reply With Quote
Old 24-01-2003, 9:32 PM   #4 (permalink)
Pierscoe1
Posts: n/a
thanks networkguy.. much appreciated
I'll give that a try and see..
Piers
P.S. E-mailed the people I got the card from, and they too said the power-connector was not something I needed to use.
Old 25-01-2003, 12:16 AM   #5 (permalink)
Pierscoe1
Posts: n/a
Tried it... no good :-(
my Cam only has "Play" of "Record" mode...
tried both, and although Premiere manages to make the camera start recording, it still records what's in front of the lens... not what Premiere is "output to tape"ing....
Any more ideas anyone?!??!
Piers.. frustrated.
Old 25-01-2003, 12:50 AM   #6 (permalink)
EvilMudge
Posts: n/a
Piers,
Does your cam have Play and Record modes,
or just a facility to let you playback footage whilst in recording mode? If not is there a setting on the camera or in the set-up menus (sorry don't know JVC DV cameras at all well) which enables DVIn?
Old 26-01-2003, 4:17 AM   #7 (permalink)
I got a power connector with my Firewire card, but with no instructions as to whether to connect it or not.
I connected it, and tried to capture footage but it didn't work. It only worked after disconnecting the cable. Weird.
Robstro is offline   Reply With Quote
camcorder, dvin
[IMG] code is Off
