Once i've recorded a video clip, and connected the camcorder to my PC via USB (has i don't have a card reader ), it's obvious i can browse to the video file....this i'm assuming has a extension of MTS??? Reading from this thread i'm assuming if i do a open with Nero Showtime, then this file with automatically play??? (I believe my Pc is powerful enough....2Ghz, 2G MB and a decent graphics card)
Unless your PC is a 2GHz Core 2 Duo or AMD Dual Core then, no, it isn't going to be fast enough to play raw AVCHD files natively.
I'm then taking it that i can just burn this file it's ins native .MTS format for archive and shold i ever wish to play again, bang it in the DVD drive and open using Nero Showtime again and it'll play just fine....
Yes.
to play in a normal DVD drive i'll have to use the HD writer software and save as mpeg2 and burn as normal, then pop it in a DVD player and away we go (this is to pass the video onto the inlaws who only have a SD DvD player, i'll be watching the Full HD version)
Yes.
to convert this MTS file to say WMV-HD (to play in the XBO360) i'll need to use something like Elements to pinnicle right??
Pinnacle 11 edits AVCHD, yes.
Thanks for any advice (and sorry if i should like a nob)
I'll assume you mean a noob? Nob has other connotations.
(has anyone tried this with the optional dvd burner (wv-bn1 - I think), which I believe does one click burn and then also plays back at the full HD res through the camera....does anyone know if this drive takes dual layer disks???)
No, and I don't know
What i really want though is to be able to archive the video files to Dvd to build a a libry and play then at will using my PC.....
You can archive the data files to DVD but you'll only be able to play them in HD using Nero, on your PC, or on a new PC actually.
I would suggest making two backups of each clip on separate external HDDs, rather than on DVD as even though DVD dyes are better than they were they still do not last forever.
Also i ready somehwre that the files can be played back in a Blu-ray player?? how is this does??? does the original stream need to be converted first?? or again, burn the original stream to dvd and just put in say the ps3???
On a PS3 you can play native AVCHD files from a DVD (as data files) from an SDHC card directly or by copying them to the HDD, but do be careful since Sony AVCHD is not the same as Panny AVCHD (wouldn't youjust know it) and you may find that Panny AVCHD won't work on a PS3.
BD player, don't know haven't got one.
Recommend using one of these:
http://www.tvix.co.kr/Eng/products/4100sh.aspx
It'll play AVCHD natively and you can shove up to a 1 terabyte drive into it and play back on your HDTV over HDMI. Neat.
