Sony HDR-HC7E or HDR-SR8E?
Old 30-09-2007, 10:26 AM   #1
7hil's Avatar
9,487, Level: 23
Points: 9,487, Level: 23 Points: 9,487, Level: 23 Points: 9,487, Level: 23
Thanks: Gave 117, Got 115
I'm leaning towards the HC7 as it's tape based and is HDV. I have a fear of everything being on hard-drives or discs. Also I think HDV will be easier to playback on an Xbox or PS3 whereas AVCHD will be more limiting to the PS3.
But the SR8E will save me having to buy tapes. It will be more convienient to use when travelling. Quicker transfer to my PC. Decisions, decisions!?!?
Old 30-09-2007, 9:42 PM   #2
7hil's Avatar
9,487, Level: 23
Re: Sony HDR-HC7E or HDR-SR8E?
So Hard Drive or Tape?
Old 30-09-2007, 10:31 PM   #3
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
I would go tape
You have the opportunity to make WMV-HDs . put them on a DVD and use them in the HD DVD Xbox 360 add-on
and also use m2t files on PS3 so the best of both worlds. AVCHD is PS3 only
Your tapes are a small cheap ready archive which don't need you to require HDDs for storage / backup / archiving before, or after editing ( if desired)
HDV is very slightly better quality ( not by much though)
and
Editing from tape is easier and more mainstream
If you stock up on tapes while travelling the HDD disadvantage disappears and it certainly will if you fill up the HDD unless you have downloaded to a laptop to free it up
The disadvantages are real time transfer on the PC and the need to swap tapes ( after 1 hr of recording) but the wide user base and the fact that Semi Pro/ Pro version camcorders still use tape mean that you are not getting an old dying format
Old 01-10-2007, 7:31 AM   #4
redsox_mark's Avatar
22,297, Level: 36
Points: 22,297, Level: 36 Points: 22,297, Level: 36 Points: 22,297, Level: 36
Thanks: Gave 90, Got 749
As Senu has said. Remember, if you go for HDD you don't need to buy media upfront, but you still need to worry about how you are going to archive backups of your material. And depending how much you shoot tape can actually be more convienent - just buy more tapes if you run out (or carry a lot with you)... rather than having to carry a laptop or other device to download to.
As I've keep saying (so apologies for the repetition), to me the big advantage of a HDD/AVCHD cam is if you don't want/need to edit on the PC at all. On the camcorder you can delete the clips you don't want, copy the ones you do quickly to a PC and burn to disc etc. If you are going to do editing on a PC that takes some time anyway; and you really need to watch your footage to determine what edits to make. You can watch your footage and make notes during that real time capture.
Old 01-10-2007, 9:05 AM   #5
7hil's Avatar
9,487, Level: 23
Cheers Guys. I will probably go tape as archiving on HDD can be a nightmare. I've already had an external HDD die on me. Would be terrible for that to happen with home video footage.
Where has been the cheapest and best place to get the tapes from?
Also do you know of any good sites to download HDV M2V (or do I mean M2T) clips for testing?
Old 01-10-2007, 10:57 AM   #6
8,270, Level: 21
Points: 8,270, Level: 21 Points: 8,270, Level: 21 Points: 8,270, Level: 21
Activity: 17.9%
Activity: 17.9% Activity: 17.9% Activity: 17.9%
Thanks: Gave 16, Got 189
Also do you know of any good sites to download HDV M2V clips for testing?
for tapes go to google and type in cheapest minidv tapes uk.chris
Old 01-10-2007, 12:19 PM   #7
22,297, Level: 36
You can find HDV clips (.m2t) all over.... Some nice example clips from a Sony FX1 here
http://www.vasst.com/HDV/FX-1_images.htm
Old 01-10-2007, 5:26 PM   #8
4,977, Level: 16
Points: 4,977, Level: 16 Points: 4,977, Level: 16 Points: 4,977, Level: 16
Thanks: Gave 1, Got 0
Originally Posted by senu View Post
I would go tape
Hello. I've been considering the same issue being discussed here and "playback-ability" is of key concern to me.
I have an XBox 360. If I were to record on the SR7/8 would there be any way for me to then convert the AVCHD on my PC into a format that I could stream to my 360?
Many thanks,
Mark.
Old 01-10-2007, 5:42 PM   #9
47,154, Level: 53
Activity: 2.7%
Many thanks,
Mark.
I suspect that AVCHD can easily become WMV-HD. A DVD disc with WMV-HD to it can play of the Xbox360s HDdVD add on .
You can stream then via the media extenders for xbox .
At any rate AVCHD cannot ( apart from on the imovie08, be imported into editing software and output back to AVCHD)
As such I imagine WMV is one of its output options
I'm not sure if this is software dependent but certainly Sony Vegas 7 e ( and now 8 are able to do this
Respighi (01-10-2007)
Old 01-10-2007, 5:47 PM   #10
4,977, Level: 16
Thanks Senu for the fast response.
I'll probe a little further before making any final decisions, but if indeed I can convert AVCHD into WMV-HD, that would solve the main potential concerns I had over playing back through my 360 (I currently have on trouble streaming WMV-HD from my PC to the 360).
Old 01-10-2007, 5:51 PM   #11
7hil's Avatar
9,487, Level: 23
I actually downloaded some m2t clips of your dogs which I think you posted on a previous thread. I burned the 50i and 60i files to a data disc with a AVCHD file I downloaded too.
The AVCHD file played fine on my PS3 but your two Dog files were very choppy on playback. Any ideas what might be causing that?
Old 01-10-2007, 6:01 PM   #12
47,154, Level: 53
Activity: 2.7%
One way of getting past this is to use the HD DVD add on.
It will enable you play HD DVD discs, make mini HD DVD discs from HiDef ( esp 60i) using standard 4.7Gb discs, and also put WMV-HD files on a DVD disc and play them rather than rely on streaming
Old 01-10-2007, 6:23 PM   #13
4,977, Level: 16
Thanks again. (I actually meant to say "I currently have no trouble streaming...", but as I do have the HD-DVD drive that seems like another useful means of storing and playing HD footage.)
Old 01-10-2007, 6:31 PM   #14
47,154, Level: 53
Activity: 2.7%
The problems of transposing one little letter . Well you have one more way of using your HD DVD drive
Old 01-10-2007, 10:40 PM   #15
7hil's Avatar
9,487, Level: 23
The problem was that I burned the clips to a CD and not a DVD.
Old 03-10-2007, 12:26 PM   #16
6,753, Level: 19
Points: 6,753, Level: 19 Points: 6,753, Level: 19 Points: 6,753, Level: 19
Thanks: Gave 31, Got 1
i went for hdv, ive got loads of other tapes in sd and wanted something to be able to play them, tapes are only a pound a go and if you go on holiday for any amount of time its less likely for me that im not going to run out of tapes where as the drive might become full.
the HD7 is a fantastic camera BTW not that ive had much experience to compare it with, im particularly impressed with the low light performance.
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
6 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 12th at 7:30pm. Prices include delivery.
[IMG] code is Off
