| Re: Panasonic NV-GS11; Help needed!
I have the same model but bought possibly over 3 years ago , so it wasn't a new model when you bought it .That said ,there a nice little camcorder with good bright picture quality, however mines developed a fault too . A red reset message appears on the screen .I have to press reset to re-activate it .Cannot think what the problem could be with yours though .If like you say ,you've pressed the reset button and it's still the same ,theres very little else you can do apart from take it to be repaired.Have you tried it using the mains adapter ,as opposed to battery . I would'nt of thought it will make a difference , but worth a try.
Technomate 1500+- Lenson 1m-Geotrack Positioner-Panasonic Th37 Plasma-Panasonic NV-GS11-Sharp VL-WD450 -C500-PIN570-Nokia770-Nokia 810-Ubiquio401&501-Imate8502-Navigos 4.3v1 & 3.5v2-
