Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 23rd at 8:30pm and include delivery.
Old 28-09-2007, 2:20 PM   #1 (permalink)
jeanlucpicard's Avatar
best true 1080p Hard Disc camcorder
what options have we now and upcoming during last Qrt?
jeanlucpicard is offline   Reply With Quote
Old 28-09-2007, 5:20 PM   #2 (permalink)
Thanks: Gave 5, Got 1
Re: best true 1080p Hard Disc camcorder
What and why is there such a drive for the highest technical video quality - it's just not that important, is it? We still watch video footage from the early days, and no-one criticizes it's quality.
It's quality content that really counts.
gritstone is offline   Reply With Quote
Old 28-09-2007, 5:54 PM   #3 (permalink)
Thanks: Gave 425, Got 2,078
The content is important.. but it is perhaps not out of place to seek knowledge about newer technologies
Whether these then translate to a "better " Audio/Visual experience is debatable. The marketing depts of the major consumer electronics dept always have a different agenda to anyone seeking "better " goods
FWIW I think hammering down 1080p as "true HD" is a marketing dream. Apart from a PS3 with 1080p games Im unconvinced that 1080i in its current implementaion lacks much compared to 1080p
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 29-09-2007, 9:45 AM   #4 (permalink)
redsox_mark's Avatar
Thanks: Gave 90, Got 749
The only 1080 HDD model with a progressive mode I'm aware of is the Canon HG10.
There is no need to choose between good content and good technical quality. Of course content is important. But when choosing a new camcorder, it is also reasonable to want to get the best technical quality you can for your money. (Whether that means it must be 1080p or not is another matter).
I have precious content shot on one of the early 8mm analogue camcorders. Sure I watch it, and it would be pointless to criticise the technical quality, as it was due to limitations of the time. But given the choice today would I want to shoot with the old analogue camcorder when I have a high def HDV cam? Of course not. There are many classic films in black and white worth watching, but would I want to buy a camcorder which didn’t support colour?
Mark
redsox_mark is offline   Reply With Quote
Old 29-09-2007, 10:00 AM   #5 (permalink)
Agree entirely..I have a friend who has held off buying a Hi def Display till the 1080p ones became more commonplace..I have no problem with that, but I certainly feel buying a non "HD Ready" ( at least 720p) TV display now is a bit ill advised.
However I would not nessesarily lust after a 1080p camcorder in the same way..for now
S3Stuff
Old 30-09-2007, 8:10 AM   #6 (permalink)
Thanks: Gave 6, Got 109
senu have you seen much stuff recorded in progessive,apart from some bits sent in to sites i have not ie on hi def tv.i know sony i recording cams will not play back canon hv20 recorded in p mode.chris
chrishull3 is offline   Reply With Quote
Old 30-09-2007, 8:26 AM   #7 (permalink)
Yes Chris, I have , but only from Bluray Movies played off a PS3 and on a 1080p display. They look fantastic but not enough to make the whole thing a "must have" for me!
I havent really seen any Camcorder progressive recording outside the short clips available for online download .
S3Stuff
Old 30-09-2007, 8:45 AM   #8 (permalink)
the blue ray movies you mention are they proper cinema films or camcorder stuff.my son has a ps3 and my standard dvd,s look fairly good on my 1080i set.what i realy want to do is put my hdv tapes onto blue ray disc,i know it means coverting them to p format first before burning blue ray disc,s i am not sure it is possible at present.chris
Old 30-09-2007, 10:49 AM   #9 (permalink)
Not camcorder stuff..Camcorder stuff has been 1080i recorded, 1080p displayed.. by the Display
As such I suspect you can put your HDV footage on Blu ray without converting them to P.
Let the Display deal with all that. The difference you achieve by converting to p ( if any) may not be worth the effort
FWIW ,I have also seen Blu ray movie discs which were not 1080p encoded and they looked great
TBH Im not very hot on BluRay media/ hardware but I know some Sony Vaio laptops have the burners, discs are available if scarce, and Software for authoring is slowly trickling in. Ive just got Ulead MovieFactory6 plus which is promising a whole lot...!
S3Stuff
Old 30-09-2007, 10:57 AM   #10 (permalink)
Thanks: Gave 0, Got 4
If your playing them on a PS3 you dont need any blu ray hardware/software at all to play them back in HD!
The playstation 3 will play back the raw M2T file from a standard DVD! just burn the m2t file to a blank DVD as a data disc and throw it in your PS3, it'll pay back the HD file flawlessly. Obviously your limited to size but use dual layer discs and youll get about 40 minutes on, a single layer will be about 20 minutes. A single HD tape over 3 DVD discs costing a quid, (a couple of quid at most for decent media)
cheers
hopthepond is offline   Reply With Quote
Old 30-09-2007, 11:04 AM   #11 (permalink)
cheers
This is correct, it is also true of AVCHD files .. In fact that you can copy any of these files to the PS3s HDD for playback ( if you want)
However the other (main) point of the post was to share with chris the fact that converting 1080i to 1080 p footage for playback via BD disc ( or not) on the PS3 is probably not nessesary
S3Stuff
Old 30-09-2007, 5:38 PM   #12 (permalink)
i doubt i will be getting a ps3 but a blue ray player or recorder sometime maybe, will the m2t dvd,s play on them the same as a ps3 i am a little vague on these points plus i am not sure if my pinnacle 10.5 will make them.the trouble is anyway m2t seems a temporary solution to storing my hdv tapes[i know they are fine stored on tape]for quick and easy playback.thanks chris
Old 30-09-2007, 6:25 PM   #13 (permalink)
Well, only time will tell. your m2t files on tape are more than a temporary solution. they are archive of your efforts and a playback medium
...Available .. here and now. In this way they are better than AVCHD even if Quality is similar. Not everybody owns or aspires to own a PS3
As for BD/ HD DVD recording, you are in the same situation as everybody else.. we are all waiting for commonplace solutions . If m2t file wont play on them as with the PS3, I'm sure they will be convert able to something which will be
There are certainly Network media players and some devices other than PS3 ect which allow you to stream media content from your PC to Display.
As for software , A the current time, Pinnacle 11 plus is already out and Ulead Movie Factory 6plus at £39 and lately Adobe Premiere Elements4 are able to Author BD video ( ironic considering the "virtual " non existence of media and affordable burners ) so I wouldnt worry too much
S3Stuff
Old 30-09-2007, 9:34 PM   #14 (permalink)
cheers i must give it some thought.but i see some have problems with m2t doing this,i would not be too optimistic who knows though.
http://www.videoforums.co.uk/dvd-svc...onversion.html
Old 30-09-2007, 9:53 PM   #15 (permalink)
I would suggest the problem isnt m2t .. it is m2t and Adobe Premiere.
For whatever reason , software like Avid Liquid 7, Sony Vegas 6 7 and now 8 and Canopus Edius HD cottoned on to HDV and its peculiarities sooner than Adobe.
Even Ulead MovieFactory 5 and 6 plus , are able to manipulate m2t
The fact is that in this regard AVCHD is less well supported than HDV so i would be far less pessimistic
Also for simple creation of SD DVD.. from tape,HDV as you know , the camcorders do a very decent job downconvertng to DV AVI on the fly
S3Stuff
1080p, camcorder, disc, hard, true
[IMG] code is Off
