Replacement Camcorder
Old 21-09-2007, 5:11 PM   #1
crol
Posts: n/a
I have a Sony Camcorder CCD-TRV46E Hi 8, which has finally given up the ghost. I was looking for a replacement and wondered which would do the equivalent job?
The one I have is 18x optical zoom (not bothered about digital) and steady shot. Other features I'm not too concerned with.
I use the camcorder for the usual events, Birthdays, holidays etc.
Any help would be appreciated.
Old 21-09-2007, 5:48 PM   #2
3,359, Level: 13
Points: 3,359, Level: 13 Points: 3,359, Level: 13 Points: 3,359, Level: 13
Thanks: Gave 5, Got 1
Re: Replacement Camcorder
A good start would be to get hold of a copy of the Argos catalogue!
Old 21-09-2007, 6:02 PM   #3
redsox_mark's Avatar
22,297, Level: 36
Points: 22,297, Level: 36 Points: 22,297, Level: 36 Points: 22,297, Level: 36
Thanks: Gave 90, Got 749
Do you have a budget in mind?
Old 21-09-2007, 6:03 PM   #4
crol
Posts: n/a
I've looked in the Argos catalogue. So, is it best to go with mini DV, DVD or HDD and is the quality of picture a lot better on the modern camcorders as opposed to the Hi8?
Old 21-09-2007, 6:07 PM   #5
crol
Posts: n/a
Budget would be approx £400. But if I could get an equivalent to my old Camcorder, picture quality wise, then I would prefer to pay less.
Old 21-09-2007, 6:19 PM   #6
22,297, Level: 36
In that budget miniDV tape will give you the best quality. I suggest Panasonic GS320
http://www.pricerunner.co.uk/pl/8-86...Prices?q=gs320
or Sony HC96, discontinued but good and good price here
http://www.ebuyer.com/UK/product/108048
Either will more than equal your old camcorder.
Old 21-09-2007, 6:31 PM   #7
22,297, Level: 36
Yes the picture is better... with the possible exception of low light performance. With analogue camcorders you can generally get a picture (though grainy) in very low light. With digital ones they reach a point where you just get darkness.
For quality, especially in your budget, miniDV is best. I'd avoid DVD for reasons which have been discussed here; some reports of problems when finalizing discs. HDD gives some convienence but you need to spend £400 up to get a good one.
Old 22-09-2007, 2:40 PM   #8
crol
Posts: n/a
So does this mean I could obtain an even cheaper model and still get the same quality in normal daylight as the Hi8?
Also what sort of situation are you talking about when you loose quality with very low light; outside in the dark?
Thanks for your help so far
Old 22-09-2007, 2:45 PM   #9
22,297, Level: 36
Yes probably... but I'd stick with £300-£400 if you can....
Yes... when it is quite/very dark. With an analogue camcorder, you'll get some picture in almost zero light (though very grainy of course). With a digital camcorder you need a minimum level of light or you get no picture at all... (unless you use a light of some sorts).
crol (22-09-2007)
Old 22-09-2007, 2:51 PM   #10
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Yes But as Mark as stated.. aim high
No could be in doors with poor tungsten/fluorescent lighting.
For instance when people want a "party" filmed and they turn the lights down low for a "Party ambience"..it is very often to the detriment of video
As such the idea is not so much to compare the low light ability of the newer miniDV with Hi8 but to acknowledge that no camcorder will not do better given better light..
Better low light ability comes with bigger sensors , Faster lenses and better electronics which may be scarce at the lower end of the price range
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
3 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 3:30am. Prices include delivery.
[IMG] code is Off
