| Re: Sony TRV240E
Hi homers,
I've got a Sony TRV245 that I've had for 5 years (well actually a bit less 'cos it replaced a 235 that broke down...). For the last year I've been using a Panasonic GS180, 3-chip camcorder (around £300), which certainly gives a much more vibrant, crisper picture outdoors / in good light. But actually in difficult(-ish) conditions, I still find the old Sony's exposure, white balance, and image stabiliser more reliable. Short story? The Sony Digital 8's are still pretty decent cams and if you're happy with its results, then you don't actually need to fix what ain't broke.
Having said that, for what you paid for the Sony could get you a very nice new SD (standard definition) camcorder now, or possibly even just about a very nice HD one. Technology has improved, and although the manufacturers have been dumbing down camcorders (stripping off useful features and controls) for cheaper models, you could certainly get a noticeable improvement over your current cam if you wanted to spend the money.
There's no way either of changing the lens on your current cam, or of making it HD (the image sensor and electronics / coding system are very strictly SD - it simply hasn't got enough pixels to "see" in HD). For consumer cams, they generally seem to be designed so all the components are set to a similar quality / budget - i.e. moving up the range, the lens, image sensor and extra controls all increase / improve together. So even if it were possible, it's not worth upgrading one part, as the other parts would then let it down.
I'm soon planning to upgrade to a HD camcorder, and the jump in image quality "wow factor" from any SD camcorder (especially a 1-chip 7-year-old one) up to HD is very impressive. There are plenty of threads around here recently about the different options for HD formats and models, but you'll probably be looking at something in the £450-£800 price range.
Digital zoom really isn't worth anything and is best left switched off, as when you start to zoom in using it, it reduces the picture resolution and starts to look rather poor. If you really needed to zoom in beyond what the lens will offer (optical zoom), you can always do the same job in editing software anyway (again reducing - or interpolating - resolution). Optical zoom of 20-25x on the Digital 8's was nice, but anything over about 15x isn't often used all that helpfully because of the amount of wobble you see when you're that zoomed in (unless you've got a good tripod &/or are a wildlife cameraman!).
