Originally Posted by Pantalone So question is do I buy the Sony cable for about £25, or is there a better one available? This is new territory for me, I'm assuming that the iLink cable will plug directly into my Dell PC? or is there something else I need...Advice greatly appreciated. |
Unless faulty , a firewire cable is a firewire cable (Sony calls them I-link) and in truth
you can use any as long as you get a 4-pin (camcorder end ) to 6 pin or 4 pin ( to the PC: laptops tend to have 4 pin as well )
The fit is usually standard. the only caveat to that is that some camcorders have a ressesed jack and a firewire cable with thicker plastic moulding may not fit in well so try before you buy (if you can) But don't feel compelled to buy Sony's own brand i-link cable . It is ( like most Sony stuff) needlessly overpriced
