Your link is to Ver 6 There is (was) a ver 7 not available in the UK
The latest is
Ver 8 which is Windows Vista friendly and perhaps the one to go for now . I think £60 is a bit much to pay for a product which has had 2 major updates especially as the newest version is unlikely to cost a great deal more but YMMV.
I think it is rather good, quite popular and it has great tutorials but some folk take a while to get used to its GUI
But
| Is there something better? |
What you have described can be done with virtually
any of the currently available software titles (Adobe Premiere Elements , Pinnacle Studio, Ulead Video Studio ,Serif.. Magix Movie Studio ect)
The differences are mainly
Ease of use
Graphic user interface and how you get on with it
Stability
Upgrade path ( if you chose to become Semi pro
Computer minimum Specifications
The actual features are broadly similar and the level of Use cuts in range from novice to advanced amateur Even Semi pros may use them for short projects which dont need fine level of control , as the output quality from them tend to be respectable
Most of the titles ( including this one at least the latest version) are available as download trial versions so you can ( up to a point) , try before you buy. Most also have online tutorials , Forums, third party books and training CDs ect
