VCD conversion to DVD using Vegas 7
Old 13-08-2007, 9:42 AM   #1
3,884, Level: 14
Points: 3,884, Level: 14 Points: 3,884, Level: 14 Points: 3,884, Level: 14
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 6, Got 9
Dear Friends,
after a long time i am back in to this forum for your help again, Can some one help me on this i wanna combine 2 VCDs in to 1 DVD using Vegas 7 , i know i have to convert VCD files in to .avi and please tell me how can i do that ,also when i combine i wanna the movie to play continously , no one should know about the split also the audio what format i choose ac3 stereo or PCM stereo , which one sounds better , can some one explain to me step by step how to get this sorted out please help me
Rgds
Nizam
Old 13-08-2007, 1:00 PM   #2
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Re: VCD conversion to DVD using Vegas 7
Nizam.. you still owe me!!!
Anyway what you ask is fairly simple
You do not need to convert the VCD to AVI as such
What you do is Explore the VCD
Then open the folder MPEGAV
This contains the actual video files . They are mpeg1 files
However you find them called AVSEQ 01, 02 ect with a filename extention *.dat
You need to rename them as *.mpg As such AVSEQ01.dat becomes AVSEQ01.mpg
If you cannot see the *. dat extention you need to change your file properties in Windows explorer
Like THIS
Unless you rename them, they will not be visible to Vegas ( or any other video editing software for that matter,) as video files.
Once renamed as *.mpg, it then becomes a simple matter of importing them into Vegas File> import > media browse to where the newly renamed file is and edit them the usual way by dragging to timeline and trimming ect
You ,of course later output to mpeg2 for DVD.
As you are going from a smaller sized lower bitrate format (mpeg1) to a larger size file with bigger pixel dimensions and higher bitrate ( mpeg2), being in a DVD will not necessarily improve video quality which wasn't there in the first place
The joining video clips (or lack of) are down entirely to your own editing skills..
As for audio AC3 is a small size good to excellent quality audio which is perhaps just a bit lower on the Hi fi scale than PCM (CD audio quality but much larger size)
In practice ,the quality difference is not much if the AC3 is well encoded
Whether as Ac3 or PCM if the original audio is not up to scratch , which ever way you encode for DVD will not improve it
Old 14-08-2007, 7:13 AM   #3
3,884, Level: 14
Activity: 1.0%
Smile Re: VCD conversion to DVD using Vegas 7
Thank you very much Senu, I know i owe you big time, the only reason i wanna do this i wanna combine 2 VCDs which is one movie in to 1 disk DVD , but can i get this in to one 4.7 gig single layer disk .please let me know.
Rgds
Nizam
Old 14-08-2007, 10:36 AM   #4
3,884, Level: 14
Activity: 1.0%
Hi Senu
I did exactley the same way you told me got it all right apart from when i get to the last bit i got the file name : Movie name .ac3
file type : dolby digital.ac3 or dolby digitalac3 i cannote remember
Audio 192kbps etc etc , but when i click on save a window poping up saying if you need to utilize the sourround sound you need to buy sony AC3 encoder, Do i really need that , actually i like to do it as NTSC widescreen video stream , but then it says Audio none , how can i get audio when i make file type as MPEG2 and NTSC widescreen video stream using DVD architect 4.I know you helped me in a similiar situation before , but now asking the same help again , Sorry for that , Please help me
Nizam
Old 14-08-2007, 5:54 PM   #5
47,154, Level: 53
Activity: 2.7%
Instead of using DVDA templates, why not just use a Mainconcept Mpeg2 with a DVD PAL or DVD NTSC template rather than DVD Architect streams... and dispense with the need for surround,
You can import your mpeg2 ( with sound combined) into DVDA you know
Otherwise to remind you ,If you must use separate streams, encode the footage : once as Mpeg2 DVD Architect stream . name it say..Nizam.mpg, then also save it a second time as audio.. Nizam.wav,( ac3, mp3) ect,and save both files Nizam.mpg and Nizam.wav to the same folder.. DVDA will pair them up
I gave it a go just now and I dont get a prompt to buy the encoder.. give me a call if that happens again and again
Also why do you need to make the DVDs NTSC? are they going to the US?
In my experience most VCDs are from PAL sources
Old 17-08-2007, 6:32 AM   #6
3,884, Level: 14
Activity: 1.0%
I rendered the video as DVD Pal in Vegas but then the problem is when itry to make the DVD using DVDA it wont fit in to a 4.7 gig single layer disk, if you click on File , Optimise DVD you get a window which you click on fit to disk but because i rendere the video as DVD Pal it only compressed up to 6.5 gig which is too larger than 4.7 gig, so in DVDA i have to render the video again to DVD NTSC which brings it to 4.5 gig , Please tell me why is DVD Pal takes more space than NTSC , is there any way to get round it ,Torender in DVD NTSC it took more than 8 hours.Please shed some light on this.
Nizam
Old 17-08-2007, 7:14 AM   #7
47,154, Level: 53
Activity: 2.7%
When you import into Vegas, Use an NTSC template.. When you render to mpeg2 use DVD NTSC
That way you shouldnt need to rerender in DVDA
As I said going from mpeg1 PAL to mpeg2 NTSC involves encoding to mpeg2 and transcoding from PAL to NTSC. this makes it harder to retain quality, optimise for space, and do it quickly
As for the space issue How long is the Video.. 2 Hrs?.. If you are using PCM that may be why it wont fit.. Are you now able to use ac3?
Old 17-08-2007, 9:13 AM   #8
3,884, Level: 14
Activity: 1.0%
Thanks for the reply, i did,nt use PCM i use AC3 which is fine , video is probably 2 hours 30 minutes long, but what i cannote figure out is why is it takes more space when it is in Pal ? I would prefer to do the DVD in Pal which i wanna fit it in to a 4.7 gig single layer disk, Please help me.
Nizam
Old 17-08-2007, 6:20 PM   #9
47,154, Level: 53
Activity: 2.7%
If you prefer PAL why use NTSC at all? Im not sure why it is bigger size but Im also not a fan of putting too much on a 4.7 DVD disc even though it is possible
You may need to use a variable bitrate to "tell" the software now much you want it to compress the mpeg2.. You probably have a high minimum rate of fixed bitrate which is why you cannot get it to put compress the DVD into 4.7Gb
I do however think quality will suffer even if you succeed
Old 03-09-2007, 7:06 AM   #10
3,884, Level: 14
Activity: 1.0%
Dear Senu
How do i tell the software to get a variable bit rate, or with the help of DVD Architect is there any way of putting in two disks rather than compressing the picture .But i prefer to put it in one disk?
Old 03-09-2007, 7:16 AM   #11
redsox_mark's Avatar
22,297, Level: 36
Points: 22,297, Level: 36 Points: 22,297, Level: 36 Points: 22,297, Level: 36
Thanks: Gave 90, Got 749
In Vegas, when you do render as, if you select MPEG2 and one of the DVD Architect Video Stream templates they default to VBR. You can change the settings (e.g. the bitrate) by clicking on the "custom" button.
DVD architect doesn't automatically split over multiple discs, if you want to use multiple discs you would need to do this manually (render out a part 1 and a part 2 in Vegas and author one disc with part 1, the other with part 2).
Old 03-09-2007, 7:50 AM   #12
3,884, Level: 14
Activity: 1.0%
When i render in Vegas i select as DVD NTSC beacuse i am converting a VCD to DVD formatt , so that means after selecting the template click on custom button and choose variable bit rate, is that mean i can fit to one disk when i make DVD with DVDA, Please explain
Old 03-09-2007, 8:20 AM   #13
22,297, Level: 36
Variable bit rate doesn't allow you to fit more - you fit more by reducing the bitrate. What VBR does do is help maintain the quality when using a lower bitrate.
You said your video is 2 hours 30 mins? You need to select a bitrate that will fit. Use a bitrate calculator like http://www.videohelp.com/calc.htm
A rate of 3800 would fit 2 hours 30 mins. Makes no difference if it is NTSC or PAL.
Old 04-09-2007, 7:01 AM   #14
3,884, Level: 14
Activity: 1.0%
thanks for the info, i did have a go, it shows 3 bit rates Maximum bps, Average bps, and minimum bps and it was showing a bit rate of 8000, 000 something like so i got cnfused , so can you please shed some light on this and explain to me a bit more detail ?
Old 04-09-2007, 7:23 AM   #15
47,154, Level: 53
Activity: 2.7%
Originally Posted by nizam View Post
In order to encode any other video file to mpeg2 files for DVD, the parameters of frame rate, pixel size ( for PAL or NTSC are applied) and bitrate. The first 2 parameters are fixed and the last varies
The Minimum. Average Maximum Values refer to the encoding bitrate (per second)
For bitrates per second , 3,000.000 is 3Mbps and 8,000.000 8Mbps
The lower the bitrate, the more time you can fit onto a specific size
As such
If say , you encode the same video file at 3, 6, and 8Mbps to mpeg2 respectively , you could end up with file sizes of say 150 Mb, 350 Mb or 1Gb from the same video file
This means that to fit more of a video file on a given size of disc, you need to use a lower encoding bitrate.
However, lower bitrates result in poorer looking video.
Lower bitrate are better for scenes where there is less movt.( to ensure smoothness and less "jaggies"). If you encode a fast scene with a low bitrate it may come out looking unsatisfactory (or worse really awful!!)
However depending on the original video material , encoding an mpeg2 at too high bitrates may not nessesarily result in better video quality even though you may end up with a bigger file size. Also some DVD players find it hard to decode very high bitrate encoded mpeg2s
The aim is therefore to get the encoding bitrate that will preserve good quality without being too large. As you know audio and menus also use up space, and choosing ac3 ( as you intend) is a good space saving format
Some software ( and even setoop DVD players) can show you what bitrate the mpeg2 they are playing was encoded at if you turn on display info
HTH
Old 04-09-2007, 7:44 AM   #16
22,297, Level: 36
In the Vegas settings there are 3 bitrate settings (and all are shown in bps):
Maximum
Average
Minimum
It is the Average one which is key, this will determine what the file size is. Set this to 3,800,000 for a 2.5 hour video with ac3 audio.
You can leave the Minimum and Maximum at their default values.
Old 04-09-2007, 8:27 AM   #17
47,154, Level: 53
Activity: 2.7%
Mark , having used the bitrate calculator yourself. Do you reckon it is conservative, optimistic or generally spot on?
Also although with starting material from VCD it may not matter. Do you reckon an average bitrate of 3800 ( near the minimum) will result in good quality?
I know Nizam is quite keen to put all 2 1/2 hrs on the one disc! , Hence the detail in my post ( which he did ask for)
Old 04-09-2007, 9:31 AM   #18
22,297, Level: 36
Using the bitrate calculator it is pretty much spot on if you have simple menus (it adds some overhead for the menus). If you have a lot fancy menus (with video backgrounds) then you need to tweak the numbers. Usually I take the results from the calculator and round it down to the nearest 100 MB.
Given that the original is from VCD so lowish quality to start with, I think a rate of 3800 should be OK.
Old 06-09-2007, 6:39 AM   #19
3,884, Level: 14
Activity: 1.0%
The DVD i made by the above explained way i try to copy that using Nero and DVD Fab Platinum, with both the software it showed failed to write , i dont know why ,Can someone explain to me why please?
Old 06-09-2007, 10:01 PM   #20
47,154, Level: 53
Activity: 2.7%
Nizam,
There is no reason why a DVD made by any method should fail to copy... unless the media is unreliable .. or damaged and the data is not readable for copying
I have encountered ( for a friend) similar difficulties in copying DVDs with 2 1/2 worth of video and on media which I wasn't very happy with
I have no clear explanation suffice to say rather than copy the DVD.. Make a DVD folder with DVDA and then burn a DVD video with Nero.. that will definitely work
Old 07-09-2007, 8:03 AM   #21
3,884, Level: 14
Activity: 1.0%
Thanks Senu,
what i am doing now is ripped the DVD on to my Hard disk with video_TS and audio_TS folders , them i am on the process of making extra copies of this DVD using Nero Recode, I dont know how much i am going to be successful on this , but will let you know about the end results, wait and see
Old 07-09-2007, 1:48 PM   #22
47,154, Level: 53
Activity: 2.7%
You dont ( and should not) need nero recode to make a DVD video from an existing video ts folder.
If you use the main nero program, New, DVD , DVD video all you do is import the content of your Video TS into the Blank video TS folder.
That should suffice
You dont need the audio ts folder at all as it is mostly empty
Old 12-09-2007, 5:19 AM   #23
3,884, Level: 14
Activity: 1.0%
thanks for the info, last time mark was on about setting the average bit value , and i did , but then when you go back to the template it says the last template you did nt save, can you please explain to me step by step how to do this
Nizam
Old 12-09-2007, 7:35 AM   #24
22,297, Level: 36
You started with one of the provided templates, yes? You then changed the bitrate. You can then save this as a new template (give it a name), so that you can use it again. See attached, I created a template with this specific bitrate. Type the new name in the box highlighted in the attached, and click on that little disc icon to save it.
If you don't save the template, and go back to do another render (without closing Vegas), it will show the settings you last used (but tell you it is one which you haven't saved). If you close Vegas and restart it, it won't remember these settings.
So either you can manually change the average bit rate each time, or save it as a new template and just choose that.
Old 12-09-2007, 7:43 AM   #25
47,154, Level: 53
Activity: 2.7%
Mark is once again right there.
In Vegas , and most programs like it , whether for capturing or output , whenever you chose or make a "custom" template, you get a chance to rename it and save it for future use
However unless this is your regular workflow, it is may be better to set the parameters for each specific project manually as a saved template from one might give undesirable results in another
Old 13-09-2007, 5:20 AM   #26
3,884, Level: 14
Activity: 1.0%
Thanks for all your help, this time i am with a complex operation, I got a movie on DVD which is in a 4.7 gig single layer disk, i wanna rip it to my hard drive , then like to open it with DVDA and make a DVD with copy protection so that no one shold be able to copy it, i know with DVDA you can do the copy protection, but when i try to open it with DVDA i cannote do it , shall i have to rename the file extension like last time i did for my VCD conversion or is there any other way of doing it, please help me
Nizam
Old 13-09-2007, 6:20 AM   #27
47,154, Level: 53
Activity: 2.7%
1) You cannot make DVD videos with Copy protection if not using a commercial Production workflow involving a glass master.. Same for regional coding.. Copy protection also involves getting a license from its "patent holders" or licensees
2)DVDA will usually not import DVD files ripped to HDD .. Vegas might
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 10:30am. Prices include delivery.
[IMG] code is Off
