Originally Posted by redsox_mark If the rendered video file is OK but it goes wrong at the burning to DVD stage then the problem could be with your discs or the burner.
You could try different editing software (e.g. Sony Vegas Movie Studio Platinum), but I'd also try other discs. You could also create the DVD folders with Ulead but try different software (e.g. Nero) for the burning step. |
Than you, redsox_mark,
I am going to try each of your suggestions in cost order.
I was getting really desperate, I have some holiday movies to complete for the grandchildren.
They keep asking Gramps (Me) when they will be ready to view properly.
Thanks again, I'll be in touch soon, hopefully.
Geoff
