Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 24th at 8:30am and include delivery.
Old 09-05-2007, 6:22 PM   #1 (permalink)
Thanks: Gave 2, Got 0
AVCHD Against Non Hi Def
Currently I have an old Canon MVX3i, super quality but a bit large. I also have a JVC GZ-MG21EK, quality not special but small and easy to carry. I must admit the HDD models do attract me. I have tried the GZ-MG575 and was not impressed with the PQ. I have been looking at the Sony range and whilst the AVCHD models are attractive I do not have a Blue Ray player or a HD TV. Did I see somewhere that with the AVCH models you could record in 'low' def or would you suggest something like the Sony DCR-SR190E or the 290. for good PQ and easy to carry.
Please advise
Mike
taras is offline   Reply With Quote
Old 09-05-2007, 7:02 PM   #2 (permalink)
Thanks: Gave 425, Got 2,079
Re: AVCHD Against Non Hi Def
If you can afford them , the AVCHD models can record Standard ( not low)
Def probably as well as the Non- hidef Models
Although this applies more to HDV vs DV it probably still applies .
1)It wont be too long before you get an HDTV.. there arent many which are not HDTV these days. The HD footage does look special on these Displays
2)You can record AVCHD and still output to SD mpeg2 after editng, the caveat being that the AVCDH editng software is all new and the PCs needed will need to have some "oomph". With HDV things are easier in that you can output HDV directly as SD DV
Otherwise, Just buy a non Hi def model and enjoy it for a few years, by which time the AVCHD models will possibly be less costly and the Hardware and software would be a lot more commonplace
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline   Reply With Quote
Old 09-05-2007, 7:20 PM   #3 (permalink)
redsox_mark's Avatar
Thanks: Gave 90, Got 749
With a AVCHD cam (e.g. Sony SR1) yes you have a choice, you can record in SD (MPEG2, same as other SD HDD cams), or HD (AVCHD).
Though I would suggest to record in AVCHD even if you don't have other HD kit, and do the conversion to SD in software when editing. That way you still have high def "masters" you could reissue later (eventually you'll have other HD kit).
AVCHD cams tend to have not quite as good picture quality as HDV (tape) models, but are still very good, and worth it over SD (if you have HD kit to play it on).
Stictly for SD, the SR190/290 will be as good as say the SR1. But the SR1 is more future proof.
Mark
redsox_mark is offline   Reply With Quote
Old 09-05-2007, 7:56 PM   #4 (permalink)
Hi Senu & Mark, thanks very much for your 'words of wisdom'. In the light of what you say I think it would be better to go for SR1, at least then I am 'future proof'
Mike
avchd, def
[IMG] code is Off
