Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 5:30am and include delivery.
Old 13-04-2007, 7:29 AM   #1 (permalink)
Thanks: Gave 1, Got 0
Lightbulb How will my video look on 4:3 HELP!!!
Hello everyone
I have just made a video for my 4 month old son. The camera has a native 16:9 lens and I have used VideoStudio to add effects, titles, etc. It looks great on my 16:9 TV, but before I send the DVD to my family I would like to see what it will look like on a 4:3 telly and I haven't got one. Mainly if the titles can be seen or they will be out of range.
VideoStudio can convert it to 4:3, but then it does not look that good on widescreen. Any program or VideoStudio option to check what it will look like on different sets so I can make adjustments without having to watch the movies twice, on two different tv?
Many thanks
JanderClander is offline   Reply With Quote
Old 13-04-2007, 10:31 AM   #2 (permalink)
toadoftoadhall's Avatar
Thanks: Gave 2, Got 25
Re: How will my video look on 4:3 HELP!!!
Should display fine, just with black bars top and bottom. Will look a bit small thats all compared to large ws tellys
toadoftoadhall is offline   Reply With Quote
Old 13-04-2007, 4:50 PM   #3 (permalink)
Conspicuous Member
Thanks: Gave 15, Got 463
Yep, on a 4:3 screen it should just add black bars at the top & bottom of the screen rather than chop off the sides of the picture or squeeze it.
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
MarkE19 is offline   Reply With Quote
Old 14-04-2007, 8:38 AM   #4 (permalink)
Thanks: Gave 2, Got 4
Not all TV's will letter box (black bars top and bottom) a few will actually squash the picture to 4:3. Your titles will be on screen but they and the subject will be slightly out of proportion. Most people won't notice but if you saw the footage on a 16:9 TV and then watched it squashed, you will.
If the 4:3 TV has a letter box feature it may not be automatic so check the menu options.
emocean is offline   Reply With Quote
Old 14-04-2007, 9:41 AM   #5 (permalink)
Thanks: Gave 425, Got 2,078
The DVD video player may ( in addition to the TV) have display options
which (as stated) may not be selected automatically
Wide
Pan and scan
Letterbox
Varying any of these display options may enable your Picture show in a way that looks "right" regardless of how it was recorded.
You are right that converting aspect ratio in software may lead to "unpredictable" results...not a good idea
Regardless of aspect, the software should give you "Display Safe" areas to stick to to avoid cutting off titles ect
BTW IIRC It isnt the lens that determines the recording aspect ratio, it is the sensor
senu is offline   Reply With Quote
video
[IMG] code is Off
