Capturing vhs tapes to pc with sony dv cam
Old 08-04-2007, 3:18 PM   #1
AMCross's Avatar
8,710, Level: 22
Points: 8,710, Level: 22 Points: 8,710, Level: 22 Points: 8,710, Level: 22
Thanks: Gave 122, Got 107
hi there
newbie when it comes to pc editing
have loads of dv tapes captured on sony PC110E and can get them onto pc using roxio/nero etc and they seem to be avi files
i have 4 vhs tapes that i want on my pc to edit i can capture these but they appear as mpeq files using a capture card pvr 150mce device
is that good enough to retain what quality there is on those tapes ?
i seem to recall using my new camcorder a few years ago and digitised the hi 8 tapes onto dv tapes
can i do this also from vhs to blank dv tape in the camera ?
when i try to use the digital conversion in the camera the software rewinds the tape on the camcorder and when i press play on the vhs deck it does not capture anything on the software preview screen
the vhs deck has a video/sound out to av link sony cable IN and then firewire from camcorder to pc
AND Vista is a pain getting these programs to work properly
Nero freezes during capture
Roxio have not updated since oct 06 and i cannot get the roxio DLA files to see my dvdrw
Old 08-04-2007, 5:07 PM   #2
29,398, Level: 41
Points: 29,398, Level: 41 Points: 29,398, Level: 41 Points: 29,398, Level: 41
Activity: 45.1%
Activity: 45.1% Activity: 45.1% Activity: 45.1%
Thanks: Gave 175, Got 1,418
Re: Capturing vhs tapes to pc with sony dv cam
Possibly - try and see what you think. VHS is not great to start with so a lower quality capture may not be noticeable, or may make it unwatchable if too bad.
Yes, it should be exactly the same as from the Hi8 camcorder but just using a VHS player instead. Or just copy direct to the PC without recording to DV tape, unless you require the digital master.
Remove the tape from cam if capturing to PC. From the capture settings in the software on the PC you need to disable device control. Press play on VCR and record on the PC and away you (should ) go.
Good luck,
Mark.
Old 08-04-2007, 5:09 PM   #3
AMCross's Avatar
8,710, Level: 22
cheers mark
i'll try that right now
i want to keep a master just incase
Old 08-04-2007, 5:22 PM   #4
AMCross's Avatar
8,710, Level: 22
Mark
as you seem quiet knowledgeable can you answer this for me
Capturing a dv tape its best to sue AVI dv Correct ?
But the vhs is mpeg2 Can these both be edited with revelant programs ok ?
And whats the best in your opinion Roxio Sony Nero Pinnicale
thanks adrian
Old 08-04-2007, 6:48 PM   #5
29,398, Level: 41
Activity: 45.1%
Mark
DV .AVI is the best capture format if you intend to do much editing as the format is uncompressed. Most editing software is mainly designed to work with it, but many of the newer versions of the popular programs are getting better with the compressed MPEG-2 format.
It is all down to the capabilities and settings in the software used. If using the camcorder as the analogue to digital converter then you can use any of the editing suites and capture to .AVI if required.
MPEG-2 being compressed is more difficault for the software to work with. But as already stated the programs are handling it better as it becomes a more popular format due to DVD & HDD cams that record in MPEG-2.
thanks adrian
It's really all down to choice. Try the demos of the software to see what you like the workflow of best. Programs such as Nero tend to be 'jack of all trades' rather than dedicated editing programs and therefore often have reduced features.
Pinnacle Studio is a great full featured program, but unstable on many PC's for no obvious reason. But on some it tends to hardly ever miss a beat and works well with a good user interface.
Ulead Video Studio is not liked by many as is said to have a poor/dated user interface.
Adobe Premiere Elements seems to be very popular, as does Sony Vegus Studio.
I've never had any experience of Roxio so can't comment on it really.
There are many other programs around that I'm sure others will recommend. A bit of searching around this forum should bring up loads of comments on all the programs along with links for trial downloads and their dedicated user forum.
Mark.
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 2:30pm. Prices include delivery.
[IMG] code is Off
