Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Samsung SMX-C10
Panasonic HDC-SD200
 More...Prices updated November 25th at 5:30am and include delivery.
Old 05-04-2007, 5:41 PM   #1 (permalink)
Thanks: Gave 5, Got 5
Capturing High Res Images from DVD?
Unsure if I'm posting this query in the right forum so apologies if not
I'm looking to have some prints done of certain scenes from some of my favourite films to hang in my house & need fairly high resolution images to start from in order to make the prints look decent at the size I'm after.
I've taken screen captures of standard def DVD's running on my computer but obviously the best (non-scaled) image I can get is at a resolution of 720 or so pixels wide with a height relative to that, which just isn't big enough.
If I were to play a high def DVD (either HD or Blu Ray) through my computer at, say, a resolution of 1680 x 1050 & take a screen cap of that, then would I be right in thinking that I'd end up with a much better quality image than if I were to do the same when running a standard def DVD on the same computer at the same resolution?
If not, & I'm just talking complete nonsense, then can anyone suggest any other methods for getting a high resolution (at least 1600 pixels in width) image from a film?
Any help greatly appreciated.
Dazed87 is offline   Reply With Quote
Old 06-04-2007, 2:35 AM   #2 (permalink)
Thanks: Gave 425, Got 2,080
Re: Capturing High Res Images from DVD?
You are right in thinking you will get a higher res Image from HD DVD / BD
How this translates to what size you want in print is rather much harder to predict. Even from Hi def sources You will probably not get more than the equivalent of 2-2.5 megapixels in digital still terms
You can of course resize images in software (Photoshop) by interploation although
Geniune fractals is much better ( costlier too esp for one off use)
senu is offline   Reply With Quote
capturing, dvd, high, images, res
[IMG] code is Off
