| Re: HC7-Stabilisation/poor coordination and stills quality
Wheels496,
Some further thought. I still agree that the HC7 is a better choice than the HC5, but having re-read your post I feel I must give a caution.
The OIS is "better" than the EIS as it doesn't tradeoff resolution to do the stabilisation like EIS does. But in terms of the ability to eliminate shake I don't think there is much difference.
And with all HD camcorders, the high resolution quality actually makes shake more noticable than with SD camcorders, even with stabilisation turned on.
Use of a tripod and/or monopod or steadycam device can help. Not wanting to assume, but combining your post with your login name - if one was shooting from a wheelchair a monopod would be a great help.
