Originally Posted by panny300 i have edited a 14 min slideshow, .. |
What are you editing with?
I doubt that you'll get a 14 min track , Classical tracks (which tend to be long) are often longer most other track 8 min Max
You can get similar 2 or 3 jazz /instrumental tracks and join them up to make 14 mins. If longer you can fade it out at the end
Im not sure what you are using but with software like Vegas ( or MS) you can import enough to fill the time , cross fade them at joins , and trim off ( fade out) the end if its too long
Otherwise any audio editor should be able to allow you import and join together such tracks as wav/ mp3 which you can then use as your main track
A free one like
Audacity should be capable .
