Originally Posted by acapaulco Hello all
....I know i have gone on but i do hope there is something inn there that will help you guys use these cameras. |
It is a bit loooong.
Just kidding some of my posts are like that too, one gets carried away in trying to be helpful.
I think the trick is to answer one query at a time as any one having difficulties will probably not read past the solution to thier immediate problem and then only ask the same thing again when they get stuck at the next stage.
In a recent similar thread, my experience was that most recent NLE software or DVD authoring programs can accept MOD files and use them without breaking into a sweat.
The very first time I used them was with Pinnacle Studio 9.4 , and most recently ( last saturday) with Avid Liquid 7 ( ...no sweat..it was cold anyway
The point is that once the video files are successfully downloaded on ones PC , You can do pretty much anything with them with whichever software you like if Cyberlinks offerings are proving annoying ( or limiting)
